Radiotelegrafist Posted July 16, 2017 Share Posted July 16, 2017 Va salut colegi,am si eu o rugaminte la domniile voastre sa ma ajutati si pe mine cu schema acestui tv deoarece sursa este trasnita(carbonizat cablajul)detalile sunt urmatoarele:multifunctional:TDA9351PS/N3/3,cadre:LA78040B,sunet:TDA2003,memorie:24C08,sursa tranzistorizata,mentionez ca am avut foarte multe scheme tv in calculator dar din cauza faptului ca mi sa bulit HDD,ul le-am pierdut pe toate,va multumesc anticipat. Link to comment
Radiotelegrafist Posted July 16, 2017 Author Share Posted July 16, 2017 Acesta este sasiul pe care nu l-am identifivat Link to comment
leoncris Posted July 16, 2017 Share Posted July 16, 2017 (edited) https://www.electronica-pt.com/esquema/tv/akai/akai-21ct05fs-21cts84fsn-25ct06fs-29ct07fsn-chassiss20-20997/ http://www.filehost.ro/3172623369/CHINA_TV_with_TDA11105_1_pdf/ Edited July 16, 2017 by leoncris Link to comment
Radiotelegrafist Posted July 16, 2017 Author Share Posted July 16, 2017 Va multumesc domn Leoncris,dar schema difera total,sursa am refacuto la parametri normali,acum am probleme cu multifunctionalul,tensiunile de alimentare ale acestuia sunt normale doar ca nu distribuie nici un semnal,mentionez ca acest tv a fost trasnit si in acel momrnt era conectat la cablu tv,eu suspectez multifunctionalul a fi derect ,adica TDA9351,deeacea ma intereseaza tensiunile accesorizante ale acestuia,va multumesc anticipat. Link to comment
cornel1962 Posted July 16, 2017 Share Posted July 16, 2017 ...uite ceva cu TDA93XX (orientativ) : roadstar 1450kt 2050kt 2150kt chassis ve01 with tda93xx an17821 stv9302a la78040 ka5q0765 sm rar Rolsen 72FDS107 ch LPCB0018 rar Link to comment
Radiotelegrafist Posted July 16, 2017 Author Share Posted July 16, 2017 (edited) Da,va multumesc foarte mult,am sa ma focalizezr pe tensiunile respecrive,ideea este ca nu am impulsuti nici pe BO nici pe bv Edited July 16, 2017 by Giorgi tv Link to comment
FLORIN IORDACHE Posted July 16, 2017 Share Posted July 16, 2017 Vedeti daca va ajuta ! china_tda11105ps-la78040.pdf Link to comment
Radiotelegrafist Posted July 16, 2017 Author Share Posted July 16, 2017 nu-mi ramane decat sa schimb multirunctionalul titand cont de faptul ca acest tv a fost trasnit,daca este si tunerul am luato in mana,scuzatimi ewxpresia. Vedeti daca va ajuta ! da,adeasta este domn florin sunt oameni saraci care traesc numai din agricultura si o pensie vaide capul ei ,deaceea apeleaza la mine ca stie ca le fac cu bani putini,deaceea apeleaza si ei la mine,copii lor vin numai sa ca sa sa ia pe urma paaaa. nu sti in cate sate sau comune se aplica metoda aceasta dar aici asa se practica Link to comment
Radiotelegrafist Posted July 17, 2017 Author Share Posted July 17, 2017 Buna dimineata colegi,va rog sa ma ajutati si pe mine cu un dump pentru acest tv,va multumesc anticipat. am schimbat multifunctionalul si tot nu pleaca,cred ca sa dus si dump-ul. Link to comment
cornel1962 Posted July 17, 2017 Share Posted July 17, 2017 ...ce scrie pe eticheta de pe procesor ? Link to comment
Radiotelegrafist Posted July 17, 2017 Author Share Posted July 17, 2017 TDA9351C315DG Link to comment
FLORIN IORDACHE Posted July 17, 2017 Share Posted July 17, 2017 Totusi incercati cu acest dump de aici : http://www.elforum.info/topic/52181-galactic-21g180n/ . Dar sa il incercati pe o memorie noua. Link to comment
Radiotelegrafist Posted July 17, 2017 Author Share Posted July 17, 2017 nu merge sunt foarte sigur ca , este din rescrierea memoriei Link to comment
Radiotelegrafist Posted July 17, 2017 Author Share Posted July 17, 2017 chiar a devenit tot forumul o bodega si un bazar ,imi pare rau dar din cate vad.............. Link to comment
cornel1962 Posted July 18, 2017 Share Posted July 18, 2017 (edited) ...tot ce am , poate aveti noroc : ... ati verificat tensiunile pe SCL,SDA ?, eu as incerca si cu selectorul scos de pe placa ! TDA9351C310CG - 24C16 - JQCRTVJQ2101F.rar TDA9351-C331AG-070412-1H 24c08.rar TDA9351C33NC_24c08.rar Edited July 18, 2017 by cornel1962 Link to comment
