messu Posted July 12, 2017 Share Posted July 12, 2017 Imi poate recomanda cineva un programator pentru acest tip de microcontroller ? Ideal ar fi ceva care se poate construi, cat de cat usor, in regim DIY, dar este de interes si ceva care se poate cumpara de-a gata. Link to comment
orgasmo Posted July 12, 2017 Share Posted July 12, 2017 Programator care are in lista de dispozitive suportate CYC63813 ar fi SmartProg2 de la Elnec. Dupa informatiile despre CYC63813 Pag 16: http://www.cypress.com/file/139361/download In System Programming Most designs that include an enCoRe II part have a USB connector attached to the USB D+ and D– pins on the device. These designs require the ability to program or reprogram a part through the USB D+ and D– pins alone. The enCoRe II devices enable this type of in system programming by using the D+ and D– pins as the serial programming mode interface. This allows an external controller to enable the enCoRe II part to enter the serial programming mode, and then use the test queue to issue flash access functions in the SROM. The programming protocol is not USB. S-ar putea programa serial ISP cu orice interfata conectand doar: PIN16 P1.1, PIN15 P1.0, PIN17 Vdd, PIN14 Vss pentru capsula DIP18 respectiv PIN18 P1.1, PIN10 P1.0, PIN12 Vdd, PIN14 Vss pentru capsula SOIC18. Link to comment
messu Posted July 12, 2017 Author Share Posted July 12, 2017 Hmmm, da, e interesant programatorul de la Elnec, dar trebuie sa recunosc ca pretul e un pic cam... Nu c-as fi zgarcit, dar pentru o singura proba cu un microcontroller, cred ca e un pret cam mare. Probabil ca programatorul acela se adreseaza, in principal, utilizatorilor mai...seriosi. Oricum, multumesc pentru sugestie ! Incerc sa gasesc un uC si sa fac un test cu un programator serial. Poate am noroc... Link to comment
