doru tv Posted June 22, 2017 Share Posted June 22, 2017 Salut.ce echivalent are acest mosfet care este din sursa unui tv lcd panasonic.multumesc Link to comment
Guest Posted June 22, 2017 Share Posted June 22, 2017 (edited) [PDF]R8008ANX - ROHM Semiconductor rohmfs.rohm.com/en/products/databook/.../r8008anx-e.pdf - Traducerea acestei pagini R8008ANX. Nch 800V 8A Power MOSFET. Datasheet. lOutline. VDSS. 800V. RDS(on)(Max.) 1.03Ω. ID. ±8A. TO-220FM. PD. 66W. lInner circuit. lFeatures Probabil orice mos de 800V--8A--1ohm http://www.alldatasheet.com/view.jsp?Searchword=8N80 Edited June 22, 2017 by Guest Link to comment
bogdan546 Posted June 22, 2017 Share Posted June 22, 2017 In primul rand in afara de 800v. 8A ( poate fi si 650v ) Ciss trebuie sa fie cel mult 1080pF. Deci un tranzistor cu aceasta capacitate de intrare si tensiunea de la 650v in sus ar fi bun Link to comment
Guest Posted June 22, 2017 Share Posted June 22, 2017 @bogdan: fara sa stii schema, pui un mos de 650V in locul unuia de 800V ? Chiar saptamana asta am reparat o sursa LCD FORWARD, ceea ce rar am intalnit. Ai pune acolo un mos de 650V in loc de 800/900 ? Chiar sa puna o firma ca Panasonic un tranzistor la plesneala ? Link to comment
doru tv Posted June 23, 2017 Author Share Posted June 23, 2017 Problema este ca nu gasesc acest mosfet,si nu gasesc un echivalent cu aceleasi caracteristici!stie cineva un echivalent direct? 1 Link to comment
bogdan546 Posted June 23, 2017 Share Posted June 23, 2017 Daca intrdevar este sursa forward ar putea fi o problema pentru ca la intervalul t2 tensiunea teoretica pe Q este 2V1. Nu aveti alta alternativa decat achizitonarea originalului de la farnell Link to comment
