cuuiu Posted May 23, 2007 Share Posted May 23, 2007 Am o problema cu el deoare-ce cel ce la adus la reparat afost pre zgarcit prima data si a apelat la carpaci,lipsesc piese din el si fara o schema nu vreau sa-l stric mai rau. KENDO CT 20 S71VT Procesor:sda 555xfl,j.tda8843,sasiu {11AK19P} cred ca nu am gresit cu sasiul.Din el lipseate bobina L602,TZ Q603,R629.Cred ca problema este EW dar daca ma-ti putea ajuta cu o schema sau un sfat mi-ar fi mai usor,si daca tot sant la rubrica PLANGACIOSI as vrea sa pot intra si meniu servis,sunt sigur ca va fi nevoie,Nu are telecomanda.PS.Rog ami fi scuzate greselile sunt ancepator. :prayer: Link to comment
maresmircea57 Posted May 23, 2007 Share Posted May 23, 2007 Aveti aici schema ,chassis 11ak19p Link to comment
cuuiu Posted May 23, 2007 Author Share Posted May 23, 2007 Multumesc pentru proptidune,sper sa ma descurc maine.MULTUMESC MULT. Link to comment
mariancalinescu Posted May 24, 2007 Share Posted May 24, 2007 merge oricare din telecomenzile: 2040,1940,2440 menu service: menu sau install 4,7,2,5 dupa ce montezi piesele lipsa, refa lipiturile in zona linii si e-w. Link to comment
cuuiu Posted May 24, 2007 Author Share Posted May 24, 2007 Am reusit,va multumesc anticipat. Link to comment
