Jump to content
Programare ARM
Guest mihail.stoica
 Share
Guest mihail.stoica
Buna ziua
Vin din zona microcontrolere PIC16F.., PIC18F.. asa ca la ARM sunt pifan.
Pentru ATSAM4SD32 (procesor ARM Cortex4 de la Atmel) cu ce device il programez (bootloader, program) ?
Multumesc anticipat
Link to comment
Share on other sites
  • Replies 2
  • Created
  • Last Reply
Top Posters In This Topic
Pag. 267 din DS:
"The SAM4 series microcontrollers feature a number of complementary debugand test capabilities. The Serial Wire/JTAG Debug Port (SWJ-DP) combining a Serial Wire Debug Port (SW-DP) and JTAG Debug (JTAG-DP) portis used for standard debugging functions, such as downloading code and single-stepping through programs. It alsoembeds a serial wire trace."
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
