codrut Posted May 26, 2017 Share Posted May 26, 2017 Acet laptop nu incarca bateria,bateria este noua. Va rog o schema si o idee daca are cineva de unde ar putea fi problema. Link to comment
FLORIN IORDACHE Posted May 26, 2017 Share Posted May 26, 2017 Acet laptop nu incarca bateria,bateria este noua. Va rog o schema si o idee daca are cineva de unde ar putea fi problema. Domnul este servit ! Dati un click aici : https://elektrotanya.com/ibm_lenovo_thinkpad_x220_wistron_dasher-1_rev_sb_sch.pdf/download.html Link to comment
FLORIN IORDACHE Posted May 26, 2017 Share Posted May 26, 2017 codrut = modorandvs aveti doua conturi,nu ??? Link to comment
Guest dani502017 Posted May 26, 2017 Share Posted May 26, 2017 (edited) codrut = modoran dvs aveti doua conturi,nu ??? Cum ti-ai dat seama? aaaa acum am vazut codrut apostat modoran ti-a multumit !!!! bravo Florine Uite asa se dau de gol a uitat cu ce cont a postat Edited May 26, 2017 by dani502017 Link to comment
Rx-Tx Posted May 26, 2017 Share Posted May 26, 2017 (edited) E ca la balamuc...Sa inteleg ca unora le place electronica asa de mult incat activeaza de pe mai multe conturi...buna treaba Edited May 26, 2017 by Rx-Tx Link to comment
Guest dani502017 Posted May 26, 2017 Share Posted May 26, 2017 Nici eu nu pot intelege care e scopul ,poate ne lamuresc cei care isi fac clone!!! Link to comment
modoran Posted May 26, 2017 Share Posted May 26, 2017 NU suntem aceeasi persoana, s-a intamplat sa folosim acelasi calculator fara sa dau logout si nici colegul codrut nu a observat. Link to comment
FLORIN IORDACHE Posted May 26, 2017 Share Posted May 26, 2017 NU suntem aceeasi persoana, s-a intamplat sa folosim acelasi calculator fara sa dau logout si nici colegul codrut nu a observat. codrut - Buzau si modoran - Buzau Cam cum vine asta ??? Link to comment
FLORIN IORDACHE Posted May 26, 2017 Share Posted May 26, 2017 Probabil lucreaza cu Codrut !) Probabil,dar oricum e tot cu semnul ? Link to comment
Guest Posted May 27, 2017 Share Posted May 27, 2017 (edited) Dupa parerea mea poate cineva sa-si faca si 10 conturi , atat timp cat topicurile si postarile sunt normale , nu au tenta de lobby , nu sunt la misto ,si nici ofensatoare .... Plus ca pot fi aici si service-uri cu mai multi angajati . codrut , modoran , ati instalat driverul Power system management ?? bateria noua e originala sau replica ?? Edited May 27, 2017 by Guest Link to comment
codrut Posted May 27, 2017 Author Share Posted May 27, 2017 Salut,ca sa lamuresc problema ,suntem 2 utilizatori pe un calculator.Codrut si Modoran.Nu am fost atent cand am postat.Colegul Modoran nu a inchis contul iar eu am postat din greseala din contul lui.In afara de asta suntem persoane serioase. Am mous-ul defect de aceea au aparut de 2 ori topicul,acum l-am schimbat. Multumesc pentru raspunsuri. Link to comment
Guest dani502017 Posted May 27, 2017 Share Posted May 27, 2017 Salutare,prima data verificati daca aveti tensiunile pe pinii care alimenteaza bateria ,daca aveti tensiunile scoateti bateria din laptop intrati la device manager ---batteries si dezinstalati microsoft ac adapter si microsoft acpi-compliant control method battery ,dupa dezinstalare inchideti laptopul dupa ce se opreste introduceti bateria in laptop si porniti laptopul si astepatati sa se reinstaleze driverele.Daca nici asa nu se schimba nimic intrati si in bios si vedeti acolo daca aveti optiunea cu bateria.Ati verificat tensiunile la baterie? De obicei la Lenovo daca bateriile nu sunt originale nu le vede .Sau puteti incerca o recalibrare. Link to comment
codrut Posted May 27, 2017 Author Share Posted May 27, 2017 Acum ma apuc de verificari,revin cu rezultatul. Cum se face recalibrarea? Link to comment
