costy Posted May 8, 2017 Share Posted May 8, 2017 Nu stiu sigur daca aici e locul potrivit deci daca e cazul, rog un moderator sa mute topicul unde e mai potrivit. Pe scurt e vorba de schimbarea unui ecran grafic de la o scula Yamaha RM1x cu un alt tip de ecran In manualul de service se poate vedea pinoutul celui vechi: pin 1 - Contrast pot Pin 2 - Contrast pot Pin 3 - XD3 - 4-bit X-driver (column drive) data output Pin 4 - XD2 - 4-bit X-driver (column drive) data output Pin 5 - XD1 - 4-bit X-driver (column drive) data output Pin 6 - XD0 - 4-bit X-driver (column drive) data output Pin 7 - LP - X driver Latch pulse - LP latches the signal in the X-driver shift registers into the output data latches. Connect LP to the Y-driver shift clock on modules. Pin 8 - YD - Scan start pulse/signal- YD is the data pulse output for the Y drivers. Pin 9 - Ground Pin 10 - WF - Frame signal for X/Y driver - LCD panel AC drive output. The WF period is selected to be one of two values with SYSTEM SET command. Pin 11 - XSCL - X-driver data shift clock - The falling edge of XSCL latches the data on XD0 to XD3 into the input shift registers of the X-drivers. Pin 12 - 5V iar aici este pinoutul noului ecran am facut urmatoarele legaturi: pin ecran pin aparat 1.FLM FIRST LINE MARKER 8 YD scan start 2.Line Pulse 7. Latch pulse 3.XSCL - X-driver data shift clock 11. XSCL - X-driver data shift clock 4. LCD ac driving input 10 - WF - Frame signal for X/Y driver - LCD panel AC drive output 5,6,7,8 sunt pini de alim si contrast ce nu cred ca pun probleme 9,10,11,12 6,5,4,3 pini de date 13 Disp OFF legat la 5v pt a porni displayul 14,15,16 neconectate Rezultatul este ca ecranul nu afiseaza nimic , in schimb pot regla contrastul Intrebarea mea este, acest ecran este macar compatibil cu controllerul(SED1335F0B) din aparat sau unde am gresit? Link to comment
costy Posted May 9, 2017 Author Share Posted May 9, 2017 update , la mine a ajuns fara lcd iar acum am aflat ca facea la fel si cu lcd vechi deci posibil sa fie controllerul dus sau altceva pe placa Link to comment
