ChRS Posted May 3, 2017 Share Posted May 3, 2017 Salutare forumisti, De curand am cumparat un osciloscop analogic Kenwood, iar dupa achizitie am hotarat sa-l desfac, sa-l curat, sa-i ung contactele precum si sa-i schimb condensatorii electrolitici. Problema este ca dupa dezmembrare, am gasit un potentiometru cu traseul intrerupt. Componenta are rolul de reglaj al nivelului (level) pe Triggering. Am cautat unul asemenator pe Tme/farnell, dar nu am avut noroc. Voi atasa cateva poze cu piesa defecta. Ce solutii as avea? Link to comment
surubarila Posted May 3, 2017 Share Posted May 3, 2017 Sanatate permanenta ! E montat pe o placa si axul iese prin panoul frontal ? Nu promit dar stiu ca "m-am impiedicat" de ceva asemanator , o sa caut. Link to comment
sesebe Posted May 3, 2017 Share Posted May 3, 2017 Cred să se poate si repara prin folosirea plăcuței de la unul din comert. Link to comment
manolo Posted May 3, 2017 Share Posted May 3, 2017 Astea ar fi bune? https://www.aliexpress.com/item/Free-Shipping-10pc-RV09-type-vertical-adjustable-potentiometer-variable-resistor-1K-2K-5k-10K-20K-50K/1254730846.html?spm=2114.10010108.1000013.2.Br0LaZ&scm=1007.13339.81019.0&pvid=aaba56a3-87d4-45b2-84df-10539b64576a&tpp=1 Link to comment
leoncris Posted May 4, 2017 Share Posted May 4, 2017 https://picclick.com/3pcs-6mm-Knurled-Shaft-Single-Linear-B-10K-172010469498.html Link to comment
