costelvoicu72 Posted April 27, 2017 Share Posted April 27, 2017 buna ziua nu stiu ce trafo linii are acest tv pe eticheta nu se mai vede niciun scris sursa cu tranzistoare cale comuna TA7680AP jungla TA7698AP procesor TMP47C483AN Link to comment
Toni Marginean Posted April 27, 2017 Share Posted April 27, 2017 HR/FBT7474 dar functie de tub sunt si altele echivalente. Link to comment
winstyle Posted April 27, 2017 Share Posted April 27, 2017 https://elektrotanya.com/anitech_m-51-h_dk_sch.pdf/download.html 154-138L Link to comment
Guest Posted April 27, 2017 Share Posted April 27, 2017 Are integrat pe cadre sau tranzistoare ? Link to comment
costelvoicu72 Posted April 27, 2017 Author Share Posted April 27, 2017 (edited) https://elektrotanya.com/anitech_m-51-h_dk_sch.pdf/download.html 154-138L 154-138L este codul original al trafului ? integrat pe vertical dar nu vad ce scrie pe el Edited April 27, 2017 by costelvoicu72 Link to comment
Toni Marginean Posted April 27, 2017 Share Posted April 27, 2017 Dupa 154-138L da traf HR/FBT7462. Link to comment
winstyle Posted April 27, 2017 Share Posted April 27, 2017 154-138L este codul original al trafului ? integrat pe vertical dar nu vad ce scrie pe el Conform schemei , da . L-am găsit pe un site de componente electronice , din Arad , dar nu pot accesa pagina .Pe acest site , de obicei , se listează și echivalentul . Poate că are ca echivalent pe cel specificat de colegul Toni . Nu știu exact Link to comment
costelvoicu72 Posted April 27, 2017 Author Share Posted April 27, 2017 nu stiu cum sa atasez o foto ca puneam cu sasiul Link to comment
Toni Marginean Posted April 27, 2017 Share Posted April 27, 2017 Din schema rezulta ca nu are BV pe integrat ci pe tranzistoare! Link to comment
costelvoicu72 Posted April 27, 2017 Author Share Posted April 27, 2017 (edited) Din schema rezulta ca nu are BV pe integrat ci pe tranzistoare! nu se potriveste schema data de colegu trafo linii este fbt 7462 oare se mai gaseste ? Edited April 27, 2017 by costelvoicu72 Link to comment
Guest Posted April 27, 2017 Share Posted April 27, 2017 (edited) REVIN: acum am pus in lada cu deseuri o placa cu traf 001-220501-10=HR gasit cu G Gratis cu predare in parcarea blocului. Edited April 27, 2017 by Guest Link to comment
costelvoicu72 Posted April 27, 2017 Author Share Posted April 27, 2017 (edited) https://postimg.org/image/k2tdocxzn/ https://postimg.org/image/v3oitdq8j/ am atasat foto cu fata si spatele ce telecomanda ar trebui la acest sasiu ? Edited April 27, 2017 by costelvoicu72 Link to comment
dan-a2 Posted April 27, 2017 Share Posted April 27, 2017 (edited) In poza se vede integratul BV . !! http://www.donberg.ie/descript/h/hr_7462.htm Edited April 27, 2017 by dan-a2 Link to comment
misuraelectronic Posted April 27, 2017 Share Posted April 27, 2017 procesor TMP47C483AN daca va intreaba cineva ...oricine , procesorul corect cu care este echipat acest tvc este tmp47c433an - 3844 sau 3848 , nicidecum traznaia scrisa de dvs in citatul de mai sus . telecomanda care merge la el este p1708 de la pilot ... Link to comment
