grasi Posted April 19, 2017 Share Posted April 19, 2017 sa traiti domnilor am cumparat si eu un lcd teletech model 32715 am o problema si nu reusesc sa ii dau de cap il pornesc se aprinde ledul albastru dar el nu se aprinde am bagat si cabul nici nu se aude ,am schimbat aproape toti conzii in sursa dar degeaba rog o sugestie poate ati intampinat acest defect .stima. mentionez ca am gasit cei 2 conzi de 4700mf/6,3v umflati Link to comment
grasi Posted April 19, 2017 Author Share Posted April 19, 2017 am sa i schimb si revin cu problema multumesc domnu dan Link to comment
grasi Posted April 19, 2017 Author Share Posted April 19, 2017 am schimbat si nimic problema e ca sursa nu mi da nicio tensiune rog o schema pentru acest lcd Link to comment
SASSU Posted April 19, 2017 Share Posted April 19, 2017 Pai daca sursa nu da tensiune de ce ati sarit la dump? Primadata se ia sursa in ordine,apoi daca sursa e ok trecem mai departe. Link to comment
surubarila Posted April 19, 2017 Share Posted April 19, 2017 Sanatate permanenta ! Ce cod are sursa ? Chiar o poza ar fi utila. Link to comment
SASSU Posted April 19, 2017 Share Posted April 19, 2017 Schema se poate gasi dar trebuie un cod pentru sursa. Link to comment
grasi Posted April 19, 2017 Author Share Posted April 19, 2017 scrie pe ea 17pw20 v2 eu am gasit un smd notat ic825 iar pe el scrie B H33 Y0504 intre cei 2 pini da sarma am dezlipit un pin si asa da tot sarma Link to comment
SASSU Posted April 19, 2017 Share Posted April 19, 2017 Puneti si o poza sa vedem ce ati gasit Link to comment
grasi Posted April 19, 2017 Author Share Posted April 19, 2017 va rog sa nu va suparati dar nu am trimis niciodata si nu stiu cum, Poza o fac eu dar cum sa trimit .stima Link to comment
surubarila Posted April 19, 2017 Share Posted April 19, 2017 Cand raspunzi , in dreapta jos ai <More Reply Options> click pe el apoi alegi fisierul (poza) din PC>attach this file>post. Link to comment
yokoono Posted April 19, 2017 Share Posted April 19, 2017 (edited) Dupa codul scris este dificil de aflat ce este (mos, convertor dc-dc, diode) piesa pe care o banuiti ca este defecta. Daca intre "cei 2 pini da sarma" poate fi asta (intre pinii 1 si 3 are scurt din fabricatie). In functie de locul unde este lipita este foarte usor de aflat ce rol are. http://www.mouser.com/ds/2/149/FYD0504SA-889264.pdf Edited April 19, 2017 by yokoono Link to comment
Guest Posted April 19, 2017 Share Posted April 19, 2017 Am cautat pe schema 20 min IC825 din poza. Am aflat ca nu ar fi IC. Vorba lui @yok.. In functie de locul unde este lipita este foarte usor de aflat ce rol are. Pai este la un secundar de traf si la C857. Este dioda. http://www.st.com/content/ccc/resource/technical/document/datasheet/68/39/58/a7/fe/b4/45/ac/CD00000845.pdf/files/CD00000845.pdf/jcr:content/translations/en.CD00000845.pdf Link to comment
