Guest spanu Posted April 13, 2017 Share Posted April 13, 2017 CINE MA AJUTA SI PE MINE CU NISTE DIMENSIUNI PENTRU O CUTIE DE SUBWOOFER CU DIFUZORUL DIN TITLU.AM SA-L FOLOSESC IN MASINA VREAU SA FAC CUTIA DIN MDF CU BAS REFLEX DAR PORTUL SA FIE TIP FANTA NU ROTUND DIN TEAVA. PARAMETRI T/S SUNT URMATORI: Revc= 1.800 Ohms (coils in parallel) Fo= 26.3 Hz Sd= 0.064 M² Vas= 4.098 Ft³ Cms= 199.522 uM/N Mmd= 174.909 g Mms= 0.0184 Kg BL= 8.821 T·M Qms= 6.460 Qes= 0.703 Qts= 0.634 Levc= 0.813.9 mH SPL= 86.6 dB EPB = 37.34 Quick Tech Specs Power Handling 400Watts RMS / 800W “Peak” Frequency Range 25-500Hz Sensitivity 86.3dB/SPL @ 1.0W/1M Nominal Impedance (2) 4 ohm coils Link to comment
Guest Alin Cristescu Posted April 26, 2017 Share Posted April 26, 2017 este un difuzor pentru incinta inchisa Link to comment
