cipcirip Posted May 6, 2007 Share Posted May 6, 2007 Salutare. Am primit un rc auto BMW, sasiu BP3836P6825926. Folosirea mai multor calculatoare bp code calculator a generat insa diferite coduri, toate incorecte, din pacate. As dori sa aflu un cod corect si cu ce tasta se confirma codul. Multumesc anticipat. Cip. Link to comment Share on other sites More sharing options...
mircea626 Posted May 6, 2007 Share Posted May 6, 2007 ce coduri ai incercat pina acu? Link to comment Share on other sites More sharing options...
cipcirip Posted May 7, 2007 Author Share Posted May 7, 2007 Salutare. Am incercat 5938, care era scris pe carcasa, drept cod corect, si nu a mers...dupa care am incercat 0313, 4313, 3321, 9837, si m`am oprit, sa nu`l blochez de tot. Cu ce tasta se confirma codul?? Multumesc. Link to comment Share on other sites More sharing options...
mircea626 Posted May 7, 2007 Share Posted May 7, 2007 pai cum ti-ai dat seama ca nici unul din acele coduri nu e corect,daca nu sti cu ce se comfirma codul?daca numarul de incercari scade ,inseamna ca ai nimerit tasta de confirmare Link to comment Share on other sites More sharing options...
cipcirip Posted May 7, 2007 Author Share Posted May 7, 2007 Pai...nu stiu, dar la alte cassuri pe care le`am ,,aranjat ``,dupa ce tastam codul tastam ,,5`` sau TA(TP) si porneau. Asta nu, cel putin pina acu... Link to comment Share on other sites More sharing options...
mircea626 Posted May 7, 2007 Share Posted May 7, 2007 incearca sa pui o poza cu fata casului ,asa nu-mi dau seama Link to comment Share on other sites More sharing options...
cipcirip Posted May 7, 2007 Author Share Posted May 7, 2007 ceva in genul: doar ca in loc de AM/TP este dolby/rds iar in loc de FM I/II este AM/FM, si nu scrie Bavaria C... Link to comment Share on other sites More sharing options...
mircea626 Posted May 7, 2007 Share Posted May 7, 2007 intimplator am si eu unul identic ,numai ca al meu e deocamdata defectcodul la al tau cred ca e 4313 validarea posibil sa se faca cu una din tastele cu sageti.sau daca nu tii mai mult una din taste apasatedar te intreb,dupa ce-ai introdus unul din coduri si ai incercat validarea ,ce a aparut pe display? Link to comment Share on other sites More sharing options...
cipcirip Posted May 8, 2007 Author Share Posted May 8, 2007 apare---- pt. citeva secunde, apoi cere iar cod... Link to comment Share on other sites More sharing options...
mircea626 Posted May 8, 2007 Share Posted May 8, 2007 mai are un serial acolo 7 xxx xxx xxx da-l si pe ala .sa te uiti in el la pinii procesorului,poate a intervenit cineva in el si i-a schimbat codul Link to comment Share on other sites More sharing options...
cipcirip Posted May 9, 2007 Author Share Posted May 9, 2007 Serial 7 643 836 340 pe linga p6825926; nu pare umblat la procesor(nu are urme de lipituri ,,straine``). Link to comment Share on other sites More sharing options...
mircea626 Posted May 9, 2007 Share Posted May 9, 2007 eu zic ca 4313 este codul.daca nu merge ma gindesc ca poate a fost modificat de cineva.procesorul se poate citi fara sa fie scos de pe placa deci nu e neaparat sa fie lipituri straine pe acolo .te uiti cu atentie pe pinii lui sa vezi daca se cunoaste vreo urma ceva.eventual daca e vreun traseu care a fost intrerupt(unele procesoare se pot citi numai intrerupind anumite trasee rx,tx,reset..),depinde de interfata folosita.posibil sa-l poti face numai hard :yawinkle: Link to comment Share on other sites More sharing options...
cipcirip Posted May 10, 2007 Author Share Posted May 10, 2007 Cred ca mai are ceva defect, accepta introducerea codului de prea multe ori, mi se pare anormal, doar ieri am incercat de vreo 30 ori. Oricum multumesc pentru timpul acordat... Link to comment Share on other sites More sharing options...
mircea626 Posted May 10, 2007 Share Posted May 10, 2007 cu toate ca e putin probabil ,asigura-te ca alimentarea este facuta corect.parca pe pinii 5 si 9 sint cele 2 plusuri Link to comment Share on other sites More sharing options...
cipcirip Posted May 11, 2007 Author Share Posted May 11, 2007 Deja am folosit finalii pt a repara alte 2 cass`uri auto. Multumesc. Link to comment Share on other sites More sharing options...
Archived
