Jump to content
Sign in to follow this
dioda100
va rog o schema pentru tv Mega Vision DMQ2127txt
va rog o schema pentru tv Mega Vision DMQ2127txt a intrat ceva apa in el si e cam ruginit dar cu schema cred ca se rezolva
Share this post
Link to post
Share on other sites
chasiul pe care il am eu are procesor dw-167mn02 - c69527y -procesor teletext saa5281 si tda8362 si cred ca codul lui e cp 330 mersi e buna si cealalalta schema are vecinul unul si ii cam facea figuri
Share this post
Link to post
MULTUMESC MULT VA SUNT INDATORAT , AM INVATAT MULTE DE CAND INTRU PE ACEST FORUM SI VREAU SA SPUN CA E IN CONTINU DE INVATAT :supz:
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
