Giorgian tv Posted October 25, 2016 Share Posted October 25, 2016 Va salut colegi si buna dimineata,m-am apucat sa construesc un amplificator audio de pe o schema germana si m-am inpotmonit la acest tranzistor pe care nu il am si nici nu am lucrat cu el niciodata,teoretic stiu cam ce ar trebui dar practic nu,rog pe cei care a mai inlocuit acest tranzistor sa-mi spuna si mie cu ce la inlocuit,nu de alta dar nu vreau sa iasa artifici din montaj tinand cont de faptul ca se alimenteaza la 60v,va multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
pop_ady44 Posted October 25, 2016 Share Posted October 25, 2016 (edited) http://alltransistors.com/crsearch.php?mat=Si&struct=NPN&pc=3.7&ucb=100&uce=60&ueb=7&ic=1&tj=175&ft=50&cc=25&hfe=40&caps=TO39 Uitate aici ,aceia sunt echivalenti . Edited October 25, 2016 by pop_ady44 Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 25, 2016 Author Share Posted October 25, 2016 http://alltransistors.com/crsearch.php?mat=Si&struct=NPN&pc=3.7&ucb=100&uce=60&ueb=7&ic=1&tj=175&ft=50&cc=25&hfe=40&caps=TO39 Uitate aici ,aceia sunt echivalenti . Nimic concret,treaba asta o stiam si eu,ceva autohton vreau. Si nu mai raspunde la mizerabilul acestui forum,abtinete. Quote Link to comment Share on other sites More sharing options...
adydep Posted October 25, 2016 Share Posted October 25, 2016 Merge perfect BD139,difer? doar capsulele. Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 25, 2016 Author Share Posted October 25, 2016 Totusi mi se pare cam mic,eu m-am gandit la un BD237. Quote Link to comment Share on other sites More sharing options...
adydep Posted October 25, 2016 Share Posted October 25, 2016 Nu-i mic,BC141 are 1A ?i 60V,iar BD 139 are tot 1A dar 80V.Da,BD237 are 2A la 80V,e mai tare ca originalul. Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 25, 2016 Author Share Posted October 25, 2016 Si nu este mai bine daca este mai tare? Quote Link to comment Share on other sites More sharing options...
adydep Posted October 25, 2016 Share Posted October 25, 2016 Da,e mai bun. Quote Link to comment Share on other sites More sharing options...
zsjkuki Posted October 25, 2016 Share Posted October 25, 2016 Cauta BF257,258 sau 259 facute de IPRS. Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 25, 2016 Author Share Posted October 25, 2016 Cauta BF257,258 sau 259 facute de IPRS. Ce sa caute aceste tranzistoare intrun amplif audio?,acestia sunt buni ca finali video in tv-uri. Ce sa caute aceste tranzistoare intrun amplif audio?,acestia sunt buni ca finali video in tv-uri. Sigur teai gandit la ideea ca au capsulele identica,nu-i asa? Quote Link to comment Share on other sites More sharing options...
zsjkuki Posted October 25, 2016 Share Posted October 25, 2016 Sincer nu am citit postarea pentru ce anume are nevoie am zis doar ceva ce ar merge pe capsula TO39.Poti pune linistit si 2N2219A chiar daca asta e de comutatie. Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 26, 2016 Author Share Posted October 26, 2016 Sincer nu am citit postarea pentru ce anume are nevoie am zis doar ceva ce ar merge pe capsula TO39.Poti pune linistit si 2N2219A chiar daca asta e de comutatie. Nu,nu merge,mai ales ca acest tranzistor nu este pentru aplicati audio,citeste despre el si ai sa te convingi. Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted October 26, 2016 Share Posted October 26, 2016 Uite aici echivalenti BCX40 , 2N3019 , 2N3020 , 2N423 si treci la treaba , succes Quote Link to comment Share on other sites More sharing options...
Giorgian tv Posted October 26, 2016 Author Share Posted October 26, 2016 Uite aici echivalenti BCX40 , 2N3019 , 2N3020 , 2N423 si treci la treaba , succes multumesc dar am terminat ieri ampliful de construit,am pus un bd237 si merge beton Quote Link to comment Share on other sites More sharing options...
Join the conversation
