digix Posted October 24, 2016 Share Posted October 24, 2016 Porneste numai pe baterie si fara incarcator conectat. Dupa pornire se poate conecta incarcatorul si functioneaza normal. La incercarea de pornire cu incarcator conectat (cu sau fara baterie montata) incearca cateva secunde sa porneasca fara sa am imagine si se opreste. A intalnit cineva defectul acesta ? Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted October 24, 2016 Share Posted October 24, 2016 Incarcatoru este cel original? su unul universal Quote Link to comment Share on other sites More sharing options...
digix Posted October 24, 2016 Author Share Posted October 24, 2016 Incarcator original am testat si cu sursa de banc, face tot asa. Quote Link to comment Share on other sites More sharing options...
validae Posted October 24, 2016 Share Posted October 24, 2016 Verific? condensatorii de filtraj ai procesorului, defectul este specific de obicei la Toshiba care are un supercondensator numit NEC TOKIN situat pe partea pl?cii opus? procesorului, dar e foarte probabil s? se Quote Link to comment Share on other sites More sharing options...
digix Posted October 24, 2016 Author Share Posted October 24, 2016 La Toshiba mai vechi chiar am schimbat condensatorul ala si au mers. Cam pe aici ma gandeam si eu, nu l-am desfacut inca dar o sa merg pe pista asta pentru inceput. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 24, 2016 Share Posted October 24, 2016 Verific? condensatorii de filtraj ai procesorului, defectul este specific de obicei la Toshiba care are un supercondensator numit NEC TOKIN situat pe partea pl?cii opus? procesorului, dar e foarte probabil s? se Quote Link to comment Share on other sites More sharing options...
digix Posted October 24, 2016 Author Share Posted October 24, 2016 Am cam 1950 uF adunat. Arata asa fata/spate: Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted October 24, 2016 Share Posted October 24, 2016 Daca nu lati masurat cu un eser-metru atunci masuratoarea este nuda , din cauza ca nu se stie eser-ul la acel condesator , valoarea poate sa fie buna si cu eser marit atunci acel cond defect , dar asta trebuie masurat cu eser-metru Quote Link to comment Share on other sites More sharing options...
validae Posted October 25, 2016 Share Posted October 25, 2016 Exact acel parametru e cel mai important, reprezint? ,,rezisten?a parazit?,, aflat? practic Quote Link to comment Share on other sites More sharing options...
digix Posted October 25, 2016 Author Share Posted October 25, 2016 ESR=0.010 ohmi. Nu prea cred ca asta este problema, am pus si un 330uF in plus, se comporta identic. Quote Link to comment Share on other sites More sharing options...
validae Posted October 25, 2016 Share Posted October 25, 2016 Atunci ave?i altceva defect Quote Link to comment Share on other sites More sharing options...
Guest Posted October 25, 2016 Share Posted October 25, 2016 (edited) Eu as proceda cam asa : 1 Verificarea tuturor mosfetilor din alimentare . 2 Rescriere bios - laptopul fiind destul de vechi , deasemeni bateria sa nu fie ceva probleme pe partea de smbus iar ca rezultat bios corupt . Link bios . http://www.asus.com/support/Download/3/101/0/7/24/ 3 Reflow la chipul video ATI 216-0707009 - conexiuni dezlipite /consum exagerat de mare pe un oarecare interval de timp / protest Ec (kbc ) controler / stop . In cazul alimentari de pe baterie kbc-ul se poate comporta diferit la protectia de consum marit. 4 La fel ca la punctul 3 si pentru Nordbridge-ul SIS . Pana la (reflow , rebaling sau schimbarea chipurilor) , pentru diagniosticare , se pot tatona ambele chipuri Video si Nordbridge cu preincalzirii scurte , si incercare de start de pe incarcator . Edited October 25, 2016 by Guest Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 26, 2016 Share Posted October 26, 2016 Vedeti sa nu cumva sa aveti prin bios facuta vreo setare aiurea...adica sa nu recunoasca orice incarcator.... Am patit si eu asta...deci intrati in bios si dati un load optimal default... Iar pe urma ii dati sa salveze biosul asa,adica ii dati save changes and reset sau save & exit setup si vedeti daca sa intamplat ceva in bine sau a ramas tot la fel ca si inainte. Va doresc mult,mult succes !!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
