Guest Ioan Cojocaru_256114 Posted October 22, 2016 Share Posted October 22, 2016 Buna ziua, am un Samsung UE40D5500 care se restarteaza. Ma poate ajuta cineva cu softul care trebuie scris in memoria nand? HIGH_X6_ATSC_DVB_LED CODE: BN41-01660B MODEL: BN41-01660 MEMORIE NAND: K9GAG08U0E Multumesc. Quote Link to comment Share on other sites More sharing options...
orgasmo Posted October 22, 2016 Share Posted October 22, 2016 http://www.elforum.info/topic/117196-tv-led-samsung-ue40d5500rw-restarteaza/ http://www.elforum.info/topic/115909-tv-lcd-led-samsung-ue32d5500/ Quote Link to comment Share on other sites More sharing options...
Guest Ioan Cojocaru_256114 Posted October 23, 2016 Share Posted October 23, 2016 Multumesc pt. raspuns. Fisierele din cele 2 link-uri nu mai pot fi descarcate. Ma puteti ajuta? Soft netestat: Samsung UE40D5500RW K9GAG08U0E IC1302 LTJ400HM03-B NT.bin Quote Link to comment Share on other sites More sharing options...
orgasmo Posted October 23, 2016 Share Posted October 23, 2016 http://fastupload.rol.ro/45aa8314fb5aefeb5b7e357b5f9fc5e0.html Samsung_UE40D5500RW_K9GAG08U0E_IC1302_LTJ400HM03-B_NT.bin Samsung_UE40D5500RW_24C256_LTJ400HM03-B_NT.bin Quote Link to comment Share on other sites More sharing options...
sergionel Posted December 8, 2016 Share Posted December 8, 2016 salut,pot sa repar astfel de placi.detalii la telefon 0724203840sergiu Quote Link to comment Share on other sites More sharing options...
rdlucian Posted March 14, 2018 Share Posted March 14, 2018 Buna ziua! Ma poate ajuta si pe mine cineva cu acest soft. Va multumesc anticipat! Quote Link to comment Share on other sites More sharing options...
dan cod Posted March 16, 2018 Share Posted March 16, 2018 Ai cu ce să îl scrii? Quote Link to comment Share on other sites More sharing options...
Guest John Turtucaianu Posted June 29, 2018 Share Posted June 29, 2018 Salut. Am si eu un LCD cu un defect asemanator. Porneste normal, sta aprins 20-25 secunde, dupa care se opreste si porneste iar, bucla infinita. Model: Samsung LE32A451C1, Placa sursa: BN44-00214A (model MK32P5B) Placa de baza: BN41-00983A Am suspectat sursa, am schimbat condensatorii, verificat / refacut lipituri pe placa, dar se manifesta la fel. A fost dus la service samsung unde am primit raspuns ca este defecta placa de baza si reparatia ar costa 600 lei (mai mult decat face LCD-ul :) ), dar au confirmat ca nu este problema de la sursa ca ar fi incerca cu alta placa de sursa - > acelasi comportament. Multumesc mult pentru idee si suport. O zi buna, Ionut T Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted June 30, 2018 Share Posted June 30, 2018 softul din NAND: K9GAG08U0E corupt si trebuie rescris cu programator Quote Link to comment Share on other sites More sharing options...
Guest John Turtucaianu Posted July 2, 2018 Share Posted July 2, 2018 On 6/30/2018 at 2:43 PM, Florinel TV said: softul din NAND: K9GAG08U0E corupt si trebuie rescris cu programator Multumesc frumos Florinel. Este cineva care ma poate ajuta in acest sens? Merita efortul, televizorul era functional, nu se mai veea ca nou, avea mici pete pe fundal dar functiona. Multumesc. Ionut T Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted July 2, 2018 Share Posted July 2, 2018 Te pot ajuta eu cu scrierea nandului , ori imi trimiti nandul daca ai cu cel scoate si lipi inapoi ori trimiti placa plus sursa telecomanda si senzorul ir si te ajut eu sa rezolvi aceasta problema Quote Link to comment Share on other sites More sharing options...
Guest John Turtucaianu Posted July 3, 2018 Share Posted July 3, 2018 (edited) Bun, as avea cum sa-l scot dar sincer am ceva emotii la montare, nu stiu daca imi iese. Deci as inclina spre a doua varianta. Imi dai ceva detalii, adresa nr de telefon . Multumesc, Ionut T Edited July 3, 2018 by John Turtucaianu Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted July 3, 2018 Share Posted July 3, 2018 Trebuie sami spui si modelul de panel ca sa caut soft , alte detalii pe MP Quote Link to comment Share on other sites More sharing options...
Guest John Turtucaianu Posted July 4, 2018 Share Posted July 4, 2018 Quote Link to comment Share on other sites More sharing options...
Guest John Turtucaianu Posted July 21, 2018 Share Posted July 21, 2018 Problema TV-ul meu cu oprire la 20-30 secunde a fost rezolvata de Florinel TV. Solutie "softul din NAND: K9GAG08U0E corupt si rescris cu programator" Thx a lot Florinel, chiar ai fost Profi! Up!!!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
