iod2 Posted October 20, 2016 Share Posted October 20, 2016 are cineva vrun soft? model placa : TP.SIS231.PT.818 Quote Link to comment Share on other sites More sharing options...
stefank Posted October 20, 2016 Share Posted October 20, 2016 incercati citirea SPI si rescrierea cu bin-ul rezultat Quote Link to comment Share on other sites More sharing options...
attilaa0 Posted October 20, 2016 Share Posted October 20, 2016 Sau sa-i puneti o memorie spi noua si sa rescrieti ce ati citit din cel vechi. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2016 Share Posted October 20, 2016 Colegii au dreptate, dar eu cred ca ati incercat deja metoda .........ce panel are tv-ul? Quote Link to comment Share on other sites More sharing options...
iod2 Posted October 21, 2016 Author Share Posted October 21, 2016 PANEL ST2751AO1-4 VER2.1 Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2016 Share Posted October 21, 2016 Incercati cu acesta, este pentru stick usb http://dx.xfile.ro/download/568f69681b2e5128f30ef253e2a692d1.html Quote Link to comment Share on other sites More sharing options...
iod2 Posted October 25, 2016 Author Share Posted October 25, 2016 nu merge nici cu asta. poate are cineva in service un chinez din asta. Quote Link to comment Share on other sites More sharing options...
iod2 Posted February 3, 2017 Author Share Posted February 3, 2017 inca nu am gasit soft, poate intre timp a "procurat" cineva . Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2017 Share Posted February 3, 2017 (edited) Incearca cu asta, ai sanse foarte mari sa merga, cu softul asta am resoftat un vortex cu placa T.EME380.61 si display LTA230AP01 si a mers perfect, ca si cum ar fi fost softul original.....fara modificari prin service..... https://files.fm/u/kbnw43yg#_ Daca flashul este altul decit 25Q64, nu ai ce sa mai incerci......trebuia sa postezi si tu pina acum ce flash spi are tv-ul.....ciudata placa TP.SIS231.PT.818, nici pe net nu apare... Edited February 3, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
iod2 Posted February 3, 2017 Author Share Posted February 3, 2017 este cu 25q64. cu asta porneste dar se vede prost tare.nu ii functioneaza telecomanda. nu e pentru panelul asta. poate mai are cineva vreunul salvat. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2017 Share Posted February 3, 2017 este cu 25q64. cu asta porneste dar se vede prost tare.nu ii functioneaza telecomanda. nu e pentru panelul asta. poate mai are cineva vreunul salvat. Pentru telecomanda ai codul in fisierul text din arhiva intra in service si modifica la panel......pentru dump original, mai avem de asteptat, pina atunci s-ar putea sa ne creasca barba de un metru..... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 3, 2017 Share Posted February 3, 2017 http://remont-aud.net/dump/lcd_pdp_tv/hyundai/hyundai_h_led28v8_shassi_main_board_40_ms82_mt_mab2hg/237-1-0-34928 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2017 Share Posted February 3, 2017 http://remont-aud.net/dump/lcd_pdp_tv/hyundai/hyundai_h_led28v8_shassi_main_board_40_ms82_mt_mab2hg/237-1-0-34928 Este cu 25Q32 si nu merge, a spus in postarea #10 ca e cu 25q64...... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 3, 2017 Share Posted February 3, 2017 Merita ... incercat. Quote Link to comment Share on other sites More sharing options...
Join the conversation
