ionutz2310 Posted October 9, 2016 Share Posted October 9, 2016 Buna ziua As dori sa fac un amplificator audio cu doua module div 120 si nu pot regla bias-ul.Pentru alimentare folosesc un traf toroidal de 2X30V 4A. Am inseriat cu alimentarea multimetrul si din P1 pot doar sa -l duc pana la 10-11 mA curent de mers in gol. Tranzistorii finali nu se incalzesc aproape deloc doar tranzistorii q7 si q8 se incalzesc. Cu semnal se aud destul de bine amandoua kit-urile, si daca modific P1 nu sesizez nici o schimbare. Cum as putea sa reglez biasul si ce valori ar trebui sa am? Va multumesc pentru ajutor https://postimg.org/image/ijcrni9fz/ SCH-DIY-120.pdf Quote Link to comment Share on other sites More sharing options...
franzm Posted October 9, 2016 Share Posted October 9, 2016 Unde ati conectat multimetrul? Ati încercat sa masurati tensiunea la capetele superdiodei? Trebuie sa varieze la actionarea semireglabilului. Quote Link to comment Share on other sites More sharing options...
ionutz2310 Posted October 9, 2016 Author Share Posted October 9, 2016 Am conectat multimetrul in serie in loc la siguranta fuzibila.Unde mai exact ar trebui sa masor tensiunea? Multumesc mult Quote Link to comment Share on other sites More sharing options...
franzm Posted October 9, 2016 Share Posted October 9, 2016 La capetele lui C7. Quote Link to comment Share on other sites More sharing options...
ex.escu Posted October 9, 2016 Share Posted October 9, 2016 Atentie,in schema sunt unele erori,la Q15-17 trebuie inversat colectorul cu emitorul. Quote Link to comment Share on other sites More sharing options...
ionutz2310 Posted October 10, 2016 Author Share Posted October 10, 2016 Doar pe schema electrica sunt inversati, pe placa sunt pusi corect. Quote Link to comment Share on other sites More sharing options...
Marian Posted October 10, 2016 Share Posted October 10, 2016 N-ai si un pdf cu valorile? Quote Link to comment Share on other sites More sharing options...
George Posted October 10, 2016 Share Posted October 10, 2016 Nu are cum sa aiba. Din pacate, sorteh nu a facut publice valorile pieselor pentru acea schema. Quote Link to comment Share on other sites More sharing options...
hpavictor Posted October 10, 2016 Share Posted October 10, 2016 Ar fi putut să aibă cum dar nu a fost să fie ... Ai încercat să-l contactezi pe @Sorteh ? Quote Link to comment Share on other sites More sharing options...
Marian Posted October 10, 2016 Share Posted October 10, 2016 Ionut, daca tot pare ca nu exista varianta cu valori a schemei atunci fa o poza la fel de clara si cu spatele placii, si mai fa una si cu fata dintr-un unghi mai perpendicular pentru ca una din rezistentele de langa Q9 este ascunsa de C7, si nu se poate distinge valoarea ei. Presupun ca poate exista ceva SMD-uri pe dedesubt pentru ca lipsesc niste componente de pe fata ( sau cel putin par sa lipseasca, poate mi-au scapat mie ). Daca din poze se pot distinge valori atunci se poate edita un print cu acel pdf in care sa se adauge si valori, astfel macar stim despre ce vorbim. Am intrebat despre valori deoarece vroiam sa stiu in ce plaja este configurata superdioda. Schimbarea valorii la semireglabil este inutila, nu-ti va mari curentul maxim posibil de mers in gol indiferent ce valoare ai pune tu acolo, ceea ce trebui facut daca vrei o polarizare in gol mai mare, este sa ajustezi valorile celor 4 rezistente de la superdioda ( fie cele 2 baza-colector, fie cele 2 baza-emitor ). Quote Link to comment Share on other sites More sharing options...
George Posted October 10, 2016 Share Posted October 10, 2016 Poze: Quote Link to comment Share on other sites More sharing options...
Marian Posted October 10, 2016 Share Posted October 10, 2016 Multumiri George. Ok pai are 2k7 baza-emitor si 6k8 baza-colector, adica undeva pe la 2,3V deschidere maxima a superdiodei. Etajul final este un triplet darlington, deci 6 jonctiuni BE de polarizat, adica mai putin de 0,4V polarizare maxim posibila... Pai nu-i de mirare ca nu se poate seta curentul de mers in gol, si asa cum am zis este inutil sa se schimbe valoparea semireglabilului ( nu schimba nimic cat priveste pragul deschiderii maxime ), ceea ce trebuie facut este fie reducerea R20 fie marirea R17. Personal daca este posibil as recomanda reducerea si recalcularea ambelor valori, cu cat este mai mica rezistenta baza-colector, cu atat mai putin depinzi de beta tranzistorului. Quote Link to comment Share on other sites More sharing options...
ionutz2310 Posted October 10, 2016 Author Share Posted October 10, 2016 Va multumesc domnilor pentru ajutor, imi cer scuze ca nu am raspuns azi, sunt in delegatie si nu am avut timp sa intru. O sa fie cam greu pentru mine cu acele smd-uri, o sa incerc sa le scot de pe placa si sa le masor, sper ca in acest weekend sa reusesc. Va multumesc Quote Link to comment Share on other sites More sharing options...
Marian Posted October 10, 2016 Share Posted October 10, 2016 Daca nu ai mai lucrat cu smd-uri iar placa ta este la fel ca in pozele puse de George, atunci nu le mai scoate, incearca sa pui in locul pentru R19 o rezistenta de 2k7 sau 3k3, daca nu ai smd la valoarea asta atunci pune una normala ( tht ), apoi fara ca modulul sa fie alimentat, regleaza semireglabilul pentru maxim de rezistenta intre pinul liber si ceilalti 2 lipiti impreuna, neaparat sa faci treaba asta inainte sa alimentezi!! Apoi dai multimetrul digital pe 200mVcc sau 2Vcc ( functie de ce setare are ), si conectezi testerele la bornele rezistentelor de putere din emitorii finalilor ( cele 2 grupuri de cate 1R/3W ), conectezi pe grupul dinspre plus, pui firul rosu la borna rezistentei dinspre emitorul finalului, si firul negru la iesirea modulului. Dupa ce ai facut asta, alimentezi modulul si reglezi din semireglabil pana gasesti pe multimetru cca 10-15mV. Daca ai nelamuriri intreaba. Quote Link to comment Share on other sites More sharing options...
ionutz2310 Posted October 19, 2016 Author Share Posted October 19, 2016 Salutari, Am pus o rezistenta de 3k3 si am urmat pasii lui Marian, am reusit sa reglez la fiecare modul aprox. 15mV. Se pot lasa asa modulele sau mai trebuie reglat ceva?(valoarea de 15mV e ok sau trebuie modificata). Nu trebuie sa las radiatorul sa se incalzeasca si apoi sa refac reglajele? Acum radiatorul incepe sa se incalzeasca, inainte era rece. Va multumesc https://postimg.org/image/f2vkkyre3/ Quote Link to comment Share on other sites More sharing options...
Join the conversation
