Jump to content
Probleme cu sunetul la pornire
Guest sorinveres
Guest sorinveres
Am un tv funai vechi model 2000-MK8 care la pornire are volumul dat la maxim ceea ce este foarte enervant .Mentionez ca daca il repornesc dupa cateva minute porneste cu volumul la nivelul normal la care a functionat pana l-am oprit.Aveti vreo idee care ar fi problema?
Link to comment
  • Replies 1
  • Created
  • Last Reply
Top Posters In This Topic
Join the conversation
Guest
Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
  • Create New...
Important Information
