damian_sandel68 Posted September 28, 2016 Share Posted September 28, 2016 Buna ziua, Va rog, ce sasiu are acest tv cu multifunctional, cu eticheta, NT11126PC304BC. Pe placa are scris: HX-TOP-01Z. L-am cautat peste tot, pentru schema si nu returneaza nimic despre el! Multumesc Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 28, 2016 Share Posted September 28, 2016 Cred ca sasiu e JM-2115,dar puteti sa incercati cu schema asta de aici : http://www.eserviceinfo.com/downloadsm/57921/Leko_Leko%20TV2165.html Apasati pe butonul : >> To download the file, please, click here ! << . Quote Link to comment Share on other sites More sharing options...
damian_sandel68 Posted September 28, 2016 Author Share Posted September 28, 2016 Multumesc Dle FLORIN, schema cu leko 2165 o am dar nu corespunde pe sursa de alimentare! Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 28, 2016 Share Posted September 28, 2016 Multumesc Dle FLORIN, schema cu leko 2165 o am dar nu corespunde pe sursa de alimentare! Ok,am inteles,dar sursa cu ce integrat e facuta : STR-W6753 sau ST8812FX ??? Quote Link to comment Share on other sites More sharing options...
damian_sandel68 Posted September 28, 2016 Author Share Posted September 28, 2016 Sursa e simpla, cu tz. functioneaza bine Probleme sunt cu tensiunile din secundarul sursei, 3,3v, stby si 5v. Dar, o sa le gasesc eu! Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted September 28, 2016 Share Posted September 28, 2016 Asta se potriveste ?? ctv-21001-04.rar Quote Link to comment Share on other sites More sharing options...
tehtronics Posted September 28, 2016 Share Posted September 28, 2016 Offtopic ... saluta-l pe "primarul" CIRIMPEI" Quote Link to comment Share on other sites More sharing options...
damian_sandel68 Posted September 28, 2016 Author Share Posted September 28, 2016 A fost, dle tehtronics. Acuma este consilier! O sa i transmit. Cred ca va cunoaste si dansul. Dle DAN, este pe aproape. Multumesc Quote Link to comment Share on other sites More sharing options...
Join the conversation
