codrut Posted September 28, 2016 Share Posted September 28, 2016 Acest laptop nu recunoaste bateria ,am pus alta baterie noua si tot la fel face. Are cineva o schema? Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 28, 2016 Share Posted September 28, 2016 Acest laptop e Acer Aspire 8920 sau Acer Aspire 8920G ??? Alimentatorul laptop-ului este cel original al laptop-ului,ati incercat si cu alt alimentator ??? Astept raspuns !!! Quote Link to comment Share on other sites More sharing options...
codrut Posted September 28, 2016 Author Share Posted September 28, 2016 8920g ,alimentatorul este original , am incercat si alt alimentator. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 28, 2016 Share Posted September 28, 2016 Ok,am inteles,atunci vedeti si dvs daca va ajuta aceste doua linck-uri de aici : http://elektrotanya.com/acer_aspire_8920_8930_inventec_teton2_rev_a02_sch.pdf/download.html sau http://elektrotanya.com/acer_aspire_8920.pdf/download.html Dar daca le vreti cu banii,atunci puteti sa dati cate un click pe urmatoarele linck-uri de mai jos... http://www.laptopschematic.com/acer-aspire-8920-laptop-schematic-diagram/ http://www.laptopdesktopschematic.com/downloads/cat_view/4--motherboard-schematic-diagram/3-acer-diagram.html?start=45 Quote Link to comment Share on other sites More sharing options...
Join the conversation
