quadrall Posted September 27, 2016 Share Posted September 27, 2016 (edited) M-ar interesa unde pot gasi un pinion ptr. maşina de tocat electrica.ataşez foto cu pinionul. http://i63.tinypic.com/e8n4if.jpg Edited September 27, 2016 by quadrall Quote Link to comment Share on other sites More sharing options...
adydep Posted September 27, 2016 Share Posted September 27, 2016 Urmariti acest topic,poate va ajuta:http://www.elforum.info/topic/115952-pinion-de-ma%C5%9Fin%C4%83-de-tocat-carne-electric%C4%83/ Quote Link to comment Share on other sites More sharing options...
quadrall Posted September 27, 2016 Author Share Posted September 27, 2016 (edited) am incercat , nu am gasit ce ma intereseaza Edited September 27, 2016 by quadrall Quote Link to comment Share on other sites More sharing options...
mmihai94 Posted September 27, 2016 Share Posted September 27, 2016 Cauta pe la service-urile de electrocasnice din zona ta. Quote Link to comment Share on other sites More sharing options...
quadrall Posted September 27, 2016 Author Share Posted September 27, 2016 prin exceptie din familia electrocasnicelor in zona se repara doar masinide spalat, frigidere si cam atat .... Quote Link to comment Share on other sites More sharing options...
QQme Posted September 28, 2016 Share Posted September 28, 2016 Reparatie:polizat intariturile radiale executat 2 discuri din Al dimensionate pe degajarile obtinute, legat pinionul circular,dat 6 gauri de 3 simultan prin disc-pinion-disc, strins cu suruburi si saibe+piulite,asa merge de 2 ani. eu nu am gasit nicaieri pinion. Quote Link to comment Share on other sites More sharing options...
quadrall Posted September 28, 2016 Author Share Posted September 28, 2016 Este spart si gulerul ce ține loc de bucsa ce se monteaza pe ax. Quote Link to comment Share on other sites More sharing options...
QQme Posted September 28, 2016 Share Posted September 28, 2016 La mine era numai crapat,se poate rezolva cu o bucsa cu guler, gaura in ax si stift. Quote Link to comment Share on other sites More sharing options...
Join the conversation
