Jump to content
Sign in to follow this
dosa
tv crt orion t2155mtx-s
Probabil a fost  facuta  vreo rocada de MB  sau carcasa  , d'aia nu corespunde  :scarpin
Share this post
Link to post
Share on other sites
Am un orion model T2155MTX-8 sasiu tda12122H/N200, Memorie 24c32, vertical stv43028 sasiu UOC TOP 80PIN, sursa C00765RT. Daca are cineva un dump de memorie pentru acest tip de sasiu.Va multumesc!
Share this post
Link to post
Am pus dumpu de memorie si merge dar am dimensiunea mare pe verticala ,si ar trebui reglata si liniaritatea, dar nu reusesc sa intru in meniu service. orion model T2155MTX-8 sasiu tda12122H/N200, Memorie 24c32, vertical stv43028 sasiu UOC TOP 80PIN, sursa C00765RT.
Share this post
Link to post
Tasta verde de pe telecomanda si apoi am tastat 1923; a doua volum la 0 si am apasat simultan meniu televizor si mute de pe telecomanda cam atat am gasit pe net despre  acest tv.  Nu gasesc meniu service pt. orion model T2155MTX-8. Va multumesc!
Share this post
Link to post
Din pacate nu vrea asa, Apesi tasta Menu,selectezi Language,tastezi in ordine 1,9,2,3.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
