Jump to content
Sign in to follow this
MARLANU
Inlocuire display oled SPI Bus cu I2C
Guest cobru
DIn cate vad, codul ala foloseste u8glib pentru afisaj, deci linia asta trebuie inlocuita:
U8GLIB_SH1106_128X64 u8g(3, 4, 7, 6 , 5); // SW SPI Com: CLK = 3, MOSI = 4, CS = 7, dc = 6, RES = 5
Din pacate nu ai spus modelul exact de display pe care il ai, aici ai ce suporta libraria (s-ar putea sa nu fie suportat al tau): https://github.com/olikraus/u8glib/wiki/device
Share this post
Link to post
Share on other sites
As dori sa,l inlocuiesc cu display-ul din imaginea atasata,doar modelul acesta il gasesc pe site-urile de vanzari din tara/
http://postimg.org/image/p628cifgj/
Description:Size: 0.96Resolution: 128X64Color: BlueViewing angle: greater than 160 degreesSupported platforms: for arduino, 51 series, MSP430 series, STIM32 / 2, SCR chipsLow power consumption: 0.04W during normal operationSupport wide voltage: 3.3V-5V DCWorking temperature: -30-80 degreesVolume: 27MM * 27MM * 4.1MMDriver IC: SSD1306Communication: IIC, only two I / O portsNo font: The software takes word moduloBacklight: OLED self light, no backlightInterface:4-pinsVCC: 3.3-5VGND: GroundSCL: Serial ClockSDA: Serial Data
Share this post
Link to post
Foloseste libraria aferenta (vezi atasament).
In folderul "Examples" gasesti sketch-ul "Hello world" unde indepartezi // la linia:
U8GLIB_SSD1306_128X32 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
si verifici functionarea afisorului. Restul tine de tine ce si cum vrei sa-ti faci aplicatia dorita.
In sketch-ul postat de tine inlocuiesti:
cu linia de mai sus.
U8glib.zip
Share this post
Link to post
Din pacate nu mai gasesc in tara nici acet model de display.
As putea adapta acest display?
1.8" 128X160 SPI TFT LCD ST7735S
 SPI serial, less I/O port need
Controller: ST7735S
pcb adapter for lcd
one sd card socket
can be driverd by 8051 / AVR / PIC /ARM/STM32 ....
Resolution: QVGA 128*160 Dots
Share this post
Link to post
In cele din urma am gasit un display de 1.8 128x160 SPI,acum am probleme cu modificarea codului pentru display-u
,imi da urmatoarele erori:
sketch_may12a:33: error: 'Adafruit_ST7735_18x128x160_SWSPI' does not name a type
 Adafruit_ST7735_18x128x160_SWSPI Adafruit_GFX(/*sclk=*/ 13, /*data=*/ 11, /*cd=*/ 9 , /*cs=*/ 10, /*reset=*/ 8);
C:UsersYO2MOPDesktopsketch_may12asketch_may12a.ino: In function 'void setup()':
sketch_may12a:137: error: 'u8g' was not declared in this scope
  u8g.firstPage()
sketch_may12a:140: error: 'u8g_font_unifont' was not declared in this scop
   u8g.setFont(u8g_font_unifont);
sketch_may12a:152: error: 'u8g_font_7x13' was not declared in this scop
u8g.setFont(u8g_font_7x13)
sk.txt
Edited by MARLANU
Share this post
Link to post
Excelenta este normal sa ai erorile astea. Ai amestecat doua librarii (u8g cu Adafruit). Daca renunti la una dintre ele (de preferat u8g) nu vei mai avea probleme.
Share this post
Link to post
Multumesc pentru raspuns nico.
Am modificat codu pentru  ucglib acum imi da :error: 'Ucg' was not declared in this scope
SK.txt
Edited by MARLANU
Share this post
Link to post
Guest
Iti lipseste libraria Ucg asa cum si nico_2010 te-a indrumat sa o folosesti pe cea din postul #7.
 pe care trebuie sa o download-ezi de aici https://github.com/olikraus/ucglib .
Uitate atent pe pagina, ca vei mai gasi si alte documnete la adresa github wiki .
Edited by Guest
Share this post
Link to post
Libraria UCG  este instalata,daca nu era buna nu functiona codul cu care am testat display-ul
Posted Image
Share this post
Link to post
La mine codul din fisierul SK.txt se compileaza fara probleme (dupa ce am instalat biblioteca mentionata de va_cristi)
M-am grabit, mai testez.
OK, Ucg not declared e din cauza ca la declararea lui Ucg l-ai scris cu u mic si mai departe l-ai folosit cu U MARE. Trebuie sa fie:
Ucglib_ST7735_18x128x160_SWSPI Ucg(/*sclk=*/ 10, /*data=*/ 11, /*cd=*/ 6 , /*cs=*/ 5, /*reset=*/ 4);
Da' tot nu se compileaza nici asa:
-	 Ucg.firstPage();
nu exista. Am comentat cele 3-4 apeluri si trece mai departe pana la fonturile unicode care nici ele nu exista.
'Ucg_font_unifont' was not declared in this scope
moment in care am renuntat. Sorry.
Edited by Liviu M
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
