Jump to content
Sign in to follow this
george2014
Schema DAC-12M018 B1F
buna ziua,
 va rog o schema  de la LCD Philips 15PF4121 bloc pow+invertor=DAC-12M018 B1F
       multumesc anticipat
Share this post
Link to post
Share on other sites
,...de la rusi am luat si eu ,,dar nu se potriveste cu ce am eu ,caut blocul pow.+invertor DAC-12M018 B1F DELTA
   mulumesc pt. ajutor
Share this post
Link to post
,...lipseste blocul "Supply panel" (power +inverter cu OZ 960GN+P605,SG 684,,etc )Modulul power+invertor are codul DAC-12M018 B1F Delta.
Cu schema acestui modul daca ma poate ajuta cineva.De la rusi am gasit modulul cu codul de mai sus dar imi da numai manualul (ch.LC4.1) fara schema blocului invertor+pow.
              mutumesc de ajutor
Share this post
Link to post
In ce bloc ai probleme? in sursa cu SG6841 ? sau la invertorul cu OZ960GN ?
Share this post
Link to post
Postat Astăzi, 18:30
george2014, pe 09 Mar 2016 - 1:10 PM, a spus:Posted Image
buna ziua,
am nevoie de schema modul DAC-12M018 B1F (lcd Philips) cu OZ960GN+P605,,SG684.
In manualul cu ch.LC4.1EAB lipseste blocul respectiv (power + invertor).
    multumesc
,,,...problema rezolvata,,,am gasit schema
rezolvat cu...alt topic
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
