bobo Posted January 28, 2016 Share Posted January 28, 2016 salut. la toshiba 40bl702b cu placa mama 17mb65 nu exista sunet nici dupa reset factory. pe iesirea de casti exista sunet. este acceeasi problema cu conzi si final sunet ca la 17mb62? la acest tv se pare ca apare des acest defect. multumesc . Link to comment
dan cod Posted January 29, 2016 Share Posted January 29, 2016 Cred ca da.Daca are tot final din ala.Probeaza daca la intrare in final ai sunet. Link to comment
bobo Posted February 20, 2016 Author Share Posted February 20, 2016 alt model identic de toshiba 40bl702b fara sunet in difuzoare dar cu sunet pe mufa casti. a mers cu menu 4725-diagnostic-factory reset iar apoi instalare automata programe. la unele merge din sm iar la altele prin inlocuire final audio sau toata placa mama. Link to comment
