Guest Manuel Timofte Posted January 12, 2016 Share Posted January 12, 2016 Sunt incepator, si as dori sa ma ajutati in legatura cu aceasta schema electrica sau poate imi oferiti o schema noua. As dori sa fac sa stea acest beculet din schema aprins timp de 4 minute si apoi sa se stinga permanent ce trebuie sa mai adaug la aceasta schema si am tot facut calcule pentru a calcula t1 si t2 in functie de R1, R2, C si nu reusesc de nicio culoare. help Link to comment
miron1947 Posted January 12, 2016 Share Posted January 12, 2016 (edited) Comandat de aparitia tensiunii, sau cu un buton de comanda? Configuratia prezentata de dvs. este de astabil. Edited January 12, 2016 by miron1947 Link to comment
Guest Manuel Timofte Posted January 13, 2016 Share Posted January 13, 2016 E comandat de aparitia tensiunii ... Link to comment
Elison Posted January 13, 2016 Share Posted January 13, 2016 (edited) Din R1 si C1 se ajusteaza durata.Cu R1=470K si C1=470uF ai cam patru minute. Edited January 13, 2016 by Elison Link to comment
Guest Manuel Timofte Posted January 13, 2016 Share Posted January 13, 2016 Multumesc... cand voi ajunge acasa am sa fac proba ... multumesc mult Link to comment
miron1947 Posted January 13, 2016 Share Posted January 13, 2016 (edited) In schema atasata de d-l Elison, s-a strecurat o eroare, fara o conectare intre traseul dintre pinul 4(reset) la R2 cu traseul dintre pinul 8 la alimentare, montajul nu functioneaza. Edited January 13, 2016 by miron1947 Link to comment
Elison Posted January 13, 2016 Share Posted January 13, 2016 In schema atasata de d-l Elison, s-a strecurat o eroare, fara o conectare intre traseul dintre pinul 4(reset) la R2 cu traseul dintre pinul 8 la alimentare, montajul nu functioneaza. Functioneaza exact asa cum este in atasament. Link to comment
Guest Manuel Timofte Posted January 13, 2016 Share Posted January 13, 2016 Care atasament? Link to comment
Marian Posted January 13, 2016 Share Posted January 13, 2016 Pinul 4 indeplineste functia de reset, si este baza unui PNP, daca pinul asta este tras spre masa, PNP-ul se activeaza si trage iesirea spre masa prin activarea tranzistorului dinspre masa. Daca este pus la alimentare, PNP-ul se blocheaza si integratul isi reia functionarea normala. Elison se bazeaza in schema lui pe starea iesirii, insa chiar si presupunand o stare initiala clar definita ca fiind 1 pe iesire, totusi la un moment dat se ajunge si la 0, si atunci pinul 4 se activeaza, si se automentine asa. Numai ca eu unul nu sunt foarte sigur de starea initiala a iesirii, adica este suficient ca aceasta sa fie incerta atat cat PNP-ul sa se activeze, moment dupa care starea de reset se automentine deoarece activand pinul 4, se activeaza tranzistorul dinspre masa al iesirii si asta trage pinul 4 dupa el la masa. Prin urmare si eu cred ca nu este o alegere corecta, ci ar trebui pus la alimentare direct. Posibil totusi sa fi fost pus asa dintr-un motiv anume, desi eu unul nu-l disting, poate Elison o sa ne lamureasca. Link to comment
spark Posted January 13, 2016 Share Posted January 13, 2016 (edited) ai aici un soft pentru timer-ul 555 ___https://drive.google.com/file/d/0B0PgPr-sG9JJNnR1dWlMbXZ3TVE/view?usp=sharing te poti "juca" cu el si ai sa intelegi mai bine cum functioneaza Edited January 13, 2016 by spark Link to comment
Elison Posted January 13, 2016 Share Posted January 13, 2016 @miron1947 are dreptate, imi cer scuze pentru neatentia mea. Link to comment
Guest Manuel Timofte Posted January 13, 2016 Share Posted January 13, 2016 Am sa incerc sa fac schema dupa cum a zis domnul Miron... sa vedem daca merge Link to comment
Guest Manuel Timofte Posted January 13, 2016 Share Posted January 13, 2016 Nu e nimic cu totii gresim Link to comment
