dosa Posted February 28, 2007 Share Posted February 28, 2007 are cineva schema de sasiul asta? ( fara AA) Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 ma... :smt097 sursa de alimentare, iar schema pe care o detin este 6.2AA si pe langa ca nu se vad bine conexiunile intre trasee mai si sunt ceva diferente.ca problema cu el ...NU PORNESTE, se aude un tiuit iar tensiunea de 150v este doar 20vam avut p4na40fi in scurt, dioda zenner de 200v in scurt, iar dupa ce le-am inlocuit (in loc de p4...am pus buz90) a pornit sursa (am avut cei 150v) si la repornire (am pus panoul din fata cu led de st-by si butoane) nu a mai pornit sursa decat asa cum am aratat mai sus Link to comment
mircea626 Posted February 28, 2007 Share Posted February 28, 2007 vezi rezistentele de 1ohm din primar(traductorul).se devalorizeaza..schema o pot trimite miine,dar da adresa de mail Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 [email protected] Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 3514 , 3515...sunt bune :smt006 Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 tv-ul a fost la un prieten de al meu si mi-a spus ca nu pleca din st-by (statea led aprins) iar el a masurat ( nu stiu ce ) in grila MOS-ului si atunci a plesnit sursa Link to comment
trinetservice Posted February 28, 2007 Share Posted February 28, 2007 incercati:tranzistorul de pe 5v(este un bc) regulator serie...sau optocuplorul Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 intai trebuie sa fac sa am cei 150v din sursa si dupa aceea sa vad de st-by etc Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 :yahoo: l-am dres, pana la urma...am pus in prima faza in loc de buz90, un p4nc60, si a mai crescut tensiunea de 150v de la 25 la 45v (cred ca mergea si buz 90)am descoperit descoperirea : cele 2 condensatoare de 47uf/160v din sursa AMBELE INTRERUPTE (2515 SI 2423) SI M E R G E :bananaparty: ORICUM MERCI DE BUNAVOINTA CELOR DE MAI SUS :smt006 Link to comment
Tavi Posted February 28, 2007 Share Posted February 28, 2007 :bananaparty: :bananaparty: :bananaparty: :bananaparty: :bananaparty: :bananaparty: Link to comment
dosa Posted February 28, 2007 Author Share Posted February 28, 2007 da, tavi... :smt044 mi-ai fost de un real folos...asta era defectul... :smt006 Link to comment
Tavi Posted February 28, 2007 Share Posted February 28, 2007 pai tu aveai schema la acest sasiu si clarace anume nu se potriveste intre schema si ce aveai tu in tv ?te bucuri ca ai gasit filtrajele intrerupte :)pai cand ai probleme cu sursa , prima data pui un esr pe filtrajele din sursa si de pe tensiuni , schimbi tot ce e dubios , apoi masori la rece ce este ars, schimbi daca e cazul , si apoi daca mai sunt probleme incepi sa sapi Link to comment
dnddnd Posted November 13, 2009 Share Posted November 13, 2009 salut imi puteti trimite si mie schema pt philipsam probleme cu sursa.s-a ars dioda de stabilizare bzx 15.aflata intre grila si sursa la tranzistor P4NA40FI (care era ars si el) Link to comment
