Guest Budiul Daniel Posted February 25, 2007 Share Posted February 25, 2007 A facut cineva amplificator cu acest kit http://www.hi-end.ro/product_info.php?c ... cts_id=469. As putea sa alimentez kitul cu 2*70V si sa pun patru finali . Ar fi stabil ? Ce putere ar scoate? Vreau normal sa fac doua amplif de acest fel apoi sa le leg in punte pentru un sub de vreo 600W cel putin pe 8ohm. Link to comment Share on other sites More sharing options...
Guest cromatic Posted February 25, 2007 Share Posted February 25, 2007 Cred ca ar trebui sa mearga si la 2x70Vcc.Io l-am alimentat la 2x65Vcc intr-o masa de mixaj si mere de rupe in 4 ohmi,fara sa pun nici un final in plus :partyman: Link to comment Share on other sites More sharing options...
Guest Budiul Daniel Posted February 25, 2007 Share Posted February 25, 2007 Si la mine va merge tot in 4ohm, daca le leg in punte. Dar ma intereseaza puterea cat pot sa scot din el in varianta de mai sus? Ajung in aceasta varianta la cel putin 700W in 8ohm, stabil si nu sa-l racesc cu gheata. Link to comment Share on other sites More sharing options...
moro Posted February 25, 2007 Share Posted February 25, 2007 pentru puterea ta ar fi indeal un AV800 sau ma rog IPA800 , cauta pe forum pe aici si gasesti schemaacel amplificator scoate 820W @ 4 ohmi si 500 W @ 8 ohmi Link to comment Share on other sites More sharing options...
Guest Vasile Posted February 25, 2007 Share Posted February 25, 2007 2 kituri de alea sunt mai slabe ca un IPA300 pentru ca ala are 2 finali si ipa300 are 6 finali Link to comment Share on other sites More sharing options...
Guest Budiul Daniel Posted February 25, 2007 Share Posted February 25, 2007 Dar daca pun 4 finali pe fiecare Kit si alim la 70V ? Doua kituri de acest fel scot 800W in 8 Ohm? Link to comment Share on other sites More sharing options...
Guest Vasile Posted February 25, 2007 Share Posted February 25, 2007 mai bine iti faci IPA300 ca cam tot atatea piese contine ca asta doar ca asta e forte inghesuit kitul ala nu il recomand in bridge din urmatoarele motive1 Delayul la pornire este imposibil sa il faci la ambele la fel si unu va pompa putere in celalalt 2 Protectia la scurt trebuie reproiectata Link to comment Share on other sites More sharing options...
Guest Budiul Daniel Posted February 25, 2007 Share Posted February 25, 2007 IPA 800 nu mai exista pe stoc? Link to comment Share on other sites More sharing options...
Archived
