Jump to content
"Building" NX1000LN N-Channel Lateral MOSFET
Guest broka
The NX1000LN is based on the high performance topology of the NX150 Amplifier module.
It employs a fully complimentary Input and Voltage Amplification Stage as with the NX150 but instead uses
Bipolar transistors until it reaches the output stage.
The Output stage is a all N-channel Lateral design
Capable of power levels well in excess of 950 watts RMS continuous into 4 Ohms and 550 watts RMS into 8 Ohms.
The NX1000NL uses in its output stage Dual Die Lateral Power MOSFET's
The photos below show is the NX500NL .
The NX1000NL is otherwise identical except with Dual Die Lateral MOSFET's
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Specifications
550 Watts RMS into 8 Ohms RMS Min Continuos
950 Watts RMS into 4 Ohms RMS Min Continuos
Frequency Response: 5hz to 200khz
SIgnal to Noise Ratio -125db
this is a good proyect.... somebody has the SCHEMTATICS, DIAGRAMS, PCB LAYER ...etc????[/img]
Link to comment
  • Replies 6
  • Created
  • Last Reply
Top Posters In This Topic
hello broka , i've been quit intrested in building this amplifier , do u know if a schematic is available somewhere?if this is posible i would like to buil this module in many numbersthank you
Pai uita-te sub linia aia punctata. ce scrie?In tot cazul cred ca o sa-ti treaca entuziasmul cand o sa vezi care e pretul finalilor: BUZ901=37.48 lei (fara tva) la firma de mai sus, aia cu mov in reclama. :rolleyes: (adica aproximativ 300 lei numai finalii). Hai sa zicem ca treci pe 2SK1058 si te costa doar 100 lei.bafta :smt006
Link to comment
hey moro.....I don't have anything, the idea is to get us....i need find the pcb layers, the idea is build this amplifier....but i no have anything of this amplifier....the idea, is that we get ourselves the schemtaics, diagrams, pcb layers, etc... the idea is that we try to build this amplifier, since it is very goodthanks greeting moro....pd: and sorry for mi english. i have a little englishthanks greeting broka!!
Link to comment
Guest tymonel
Dak s-ar face ampliful asta , cam la cat ar ajunge la pretz, pt ca la ce amplifuri ,,la gata`` shi ,, de firma`` pe care le-am vazut pe paginile romanesti cu aceleashi valori de ieshire (sunt 100 % convins ca sunt ,,la pocneala'') chiar ar fi fff interesant.......cel putzin pt mine..!!! .....Am vazut lumea cum se plage pe forum de amplifurile cumparate chipurile ,,de firma'' , pe care au dat peste 1600 RON, cred ca ar fi util dak atzi posta shi pt altii mai necunoscatori un amplif BUN..!!! Va multzumesc anticipat..!!
Link to comment
Register a new account
Sign in
  • Create New...
Important Information
