Jump to content
Guest broka
IPA 800 THD%???
mmm i need more specific in %THD for thats load for IPA800??i a power amplifier made with 5 STK4050V (1000 rms) for party's, etc....is good. but is much circuits and IC's STK...thanks grreetings broka
Link to comment
Share on other sites
Specifications
820 Watts RMS into 4 Ohms
450 Watts RMS into 8 Ohms
SNR: -122dB, Distortion 0.01% 1khz
Power Supply Requirements
Mono block applications
1 x 1.2KVA Toroidal Transformer
with 2 x 65vac windings (loaded rating)
Filtering min of 10,000uf per voltage rail
1 x Bridge Rectifier MDA3504
Stereo applications
1 x 2kva Toroidal Transformer
2 x Bridge Rectifiers MDA3504
Here you go all the specifications from http://www.aussieamplifiers.com/index3.htm
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
