stefank Posted February 15, 2007 Share Posted February 15, 2007 Va rog sa ma ajutati cu modalitatea de intrare in meniul de service pt. Sanyo model CE29FFV3-F sasiu 2119 ( EB9-A ) . Manifestarea este : nu actioneaza V+ nici din telecomanda nici din tv , in meniul principal au ramas doar meniul imagine si meniul pt. sunet , cele pt. optiuni si preset au disparut . Am gasit ceva pt. un alt sasiu ( 2114 EB5-C , se intra cu V- de pe tv si butonul Verde de pe tc. ) dar nu se potriveste si pt. care se specifica , ca ar fi o optiune de resetare a memoriei volatile pentru revenire la setarile de fabrica . Multumesc . Quote Link to comment Share on other sites More sharing options...
mircea626 Posted February 15, 2007 Share Posted February 15, 2007 da o adresa de mail sa-ti trimit manualul servis Quote Link to comment Share on other sites More sharing options...
stefank Posted February 16, 2007 Author Share Posted February 16, 2007 E-mailul meu este [email protected] . Multumesc . Quote Link to comment Share on other sites More sharing options...
mircea626 Posted February 16, 2007 Share Posted February 16, 2007 il pun aici Quote Link to comment Share on other sites More sharing options...
stefank Posted February 16, 2007 Author Share Posted February 16, 2007 Multumesc . Cu ajutorul dvs. am reusit astfel : meniu service --> Meniu 2011 , la prima pozitie am gasit InitTV ( initializare setari ) ceea ce am si facut dar bineinteles dupa ce am copiat toate valorile de la 001 --> 167 ca sa le pot reface dupa reset memorie . Toate cele bune . Quote Link to comment Share on other sites More sharing options...
paun nelu Posted January 9, 2014 Share Posted January 9, 2014 nu mai deschid un alt subiect!am acelasi model dar cu o alta defectiune:il pornesti din buton , pleaca pt o sec. inalta apoi da eroare trei [asta dupa ce sa reparat sursa] Quote Link to comment Share on other sites More sharing options...
leoncris Posted January 9, 2014 Share Posted January 9, 2014 Probleme in deflexia orizontala (Q652 ) Quote Link to comment Share on other sites More sharing options...
paun nelu Posted January 9, 2014 Share Posted January 9, 2014 tz e dig. e ok/fara el am efect de perna,la rece nu am gasit nimic ars! Quote Link to comment Share on other sites More sharing options...
paun nelu Posted January 10, 2014 Share Posted January 10, 2014 nu a mai avut nimeni la reparat asa ceva? Quote Link to comment Share on other sites More sharing options...
Join the conversation
