Guest andrei1989 Posted July 14, 2015 Share Posted July 14, 2015 Buna Ziua ! am un tv orion p 2077 si se incinge integratul baleiaj vertical .tv-ul functioneaza dar se incinge f tare acel integrat. Integratul este STV5112 8807C432 va rog frumos sa ma ajutati cu cateva sfaturi. ce ii pot face ? Link to comment
cristybadea Posted July 14, 2015 Share Posted July 14, 2015 Baleaj vertical????? Poate integrat RGB ca eu asa am am gasit. Link to comment
Guest andrei1989 Posted July 14, 2015 Share Posted July 14, 2015 da, imi cer scuze ,asa este Link to comment
Florinel TV Posted July 14, 2015 Share Posted July 14, 2015 punei un radiator mai mare Link to comment
tepeleacatalin Posted July 14, 2015 Share Posted July 14, 2015 verificati tensiunile de alimentare pe acest circuit....posibil sa fie marite ceea ce duce evident la o incalzire excesiva si in timp la distrugerea lui spor si bafta Link to comment
Guest dieteticul Posted July 14, 2015 Share Posted July 14, 2015 Ce inseamna se incinge? Ai masurat cu ceva temperatura? Te referi la faptul ca nu poti tine mana pe el? Poate avea 55 grade si nu poti tine mana, iar aceasta nu este o temperatura excesiva. Link to comment
dan cod Posted July 14, 2015 Share Posted July 14, 2015 Pana la urma ce se incalzeste?BVul sau finslul video? Link to comment
iuliantv Posted July 14, 2015 Share Posted July 14, 2015 avand in vedere ca a spus si stv5112 mai mult ca sigur final video Link to comment
dan cod Posted July 14, 2015 Share Posted July 14, 2015 Ce tensiune are pe alimentare? Link to comment
