Jump to content
Dan Morar
Electronice si Componente IT
Buna
Oare playerul Sony Hi8 e functional?
Spor
Alex
Share this post
Link to post
Share on other sites
Pickup Telefunken HS 700     70 lei  lipsa ac
Modem Huawei  MT882    15 lei
functional,Incarcator 12v , manual  de utilizare
Tuner guitar acordor chitara Korg GA 40 ca nou    30 lei
Banda Magntofon Neckermann mica 8 cm diametru   10 LEI
Deck Kenwwod KX 3050   70 Lei
https://imgur.com/a/NbSophR
Japan Made  inchiderea usitei  necesita ajutor cu mana
Deck Telefunken TC 450    120 lei
VUmetre analogice
Stare foarte buna de functionare Estetic f bine Greu
https://imgur.com/a/POGDvCb
Boxe AERA Goodmans Hifi England    50 Lei
Un difuzor de bass are schimbata suspensia, cealalata trebuie schimbata
DVD player Pioneer 360K    + telecomanda noua      70 lei
https://imgur.com/a/K13TXsZ
Incarcator acumulatori Power Kit foto Olympus  20 lei
Produs nou Carte, husa , cutie originala cablu inclus Germania
https://imgur.com/a/ie3JtKZ
Tuner vintage radio Grundig T 7200  50 lei
https://imgur.com/a/g2K0aL8
CDplayer Denon DCD 680   60 Lei
Citeste bine, chiar si cele inscrise , ( unle nu ii plac si mai agata gen Fake Sony)
Yamaha TX 590RDS   100 lei
Functional, arata bine , doar  imperfectiuni pe capac
https://imgur.com/a/gKdD73g
Radio vintager AIWA AR 127 din anul 1964   75 Lei
Made in Japan
https://imgur.com/a/DRiQnei
Amplituner DUAL CR 1730   170Lei
Potentiometru de volum ar trebui putin curatat
Receptia f buna   pe FM , led maxim tuning se aprinde  cu 0.05Mhz mai sus decit frecventa postului
( pe AM nu receptioneaza  nimic)
https://imgur.com/a/jzL1KpS
Tuner JVC T- X200L PLLl Made in Japan 50 Lei
https://imgur.com/a/EX4ANz
Tuner Philips FT 880 50 lei
https://imgur.com/a/jg9QwWr
Share this post
Link to post
Amplituner stereo Kenwood KR A 3080    160 lei
Tunerul recetrioneaza  , dar nu se aprinde indicatorul  Stereo sau sa functioneze RDS
Uneori merg si aceste functii
Butonul de la selector nu cred ca e cel original
Asa a venit din germania
In rest functional
Tuning range: FM, MW
service manual pe hifiengine
Power output: 50 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.03%
Input sensitivity: 2.5mV (MM), 200mV (line)
Signal to noise ratio: 75dB (MM), 93dB (line)
Dimensions: 440 x 127 x 380mm
Weight: 6.9kg
Accessories: remote control
Year: 1996
https://imgur.com/a/JsZwLxT
Share this post
Link to post
VUmetre analogice
Made in Japan
Tunerul receptioneaza  , dar nu se aprinde indicatorul  Stereo sau sa functioneze RDS , uneori apar si functiile lipsa
Share this post
Link to post
Cd player Fine Arts CD 1 Grundig  60 lei
Functional
Citeste si cduri inscrise
La discuri foarte zgiriate uneori sare
Arata OK
https://imgur.com/a/YflikVu
Tuner Philips FT 565  60 lei
Quartz Lock Tuner Japan Made
Functional
Receptie decalata pe FM cu 0.05Mhz
42 cm x28 xm x 6 cm
Antena Loop AM
2 kg
https://imgur.com/a/f6DLlwU
Share this post
Link to post
Radio vintage Constellation anii 60 f rar    65 lei
Radio colectie perfect functional.
Adus Germania.
Are adaptat alimentare 220v ( asa a venit)
Country: France
Manufacturer / Brand: Constellation; Paris
https://imgur.com/a/tHxDFN3
Share this post
Link to post
Deck Kenwwod KX 3050   40 lei
Japan Made
3 motoare
Arata bine
A functionat play,rew, rec,ff ok
Singura problema era la inchiderea usitei ,  necesita ajutata cu mana
Acum nu mai deschide usa
https://imgur.com/a/mWsZD1Z
Edited by Dan Morar
Share this post
Link to post
Va rog sa imi spuneti ce mufe de conectare are pe spate.
Ma intereseaza daca se poate conecta la un PC pentru conversie semnal analog in digital.
Share this post
Link to post
Buna, are mufa DIN, clasica 5 pini, cu un adaptor DIN a  la jack 3,5mm cred ca se poate pune la Intrarea placii de sunet la PC,
Share this post
Link to post
Are si adaptor DIN to RCA mama  inclus in pretuil afisat
Share this post
Link to post
OK, doresc sa cumpar Deck Telefunken TC 450.
V-am trimis mp.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
