Roland Posted January 18, 2007 Share Posted January 18, 2007 Ma poate ajuta si pe mine cineva si sa-mi spuna ce integrat o fi cel de mai jos ?"Minunea" se afla intr-un cd-rw portabil , e plasat dupa un tranzistor stabilzator- DL2Z- si de la acesta,333E, care e in paralel cu anteriorul, tensiunea se duce la un microprocesor...Pe placa in dreptul lui scrie ca e integrat. | | .............. : 333E : :............: | | |Multumesc. Link to comment
Tavi Posted January 18, 2007 Share Posted January 18, 2007 hai ca ai noroc, au inventat astia camera digitala , fa-i o poza clara Link to comment
Roland Posted January 18, 2007 Author Share Posted January 18, 2007 D-le nu reusesc sa fac o poza mai ca lumea.... Link to comment
mircea626 Posted January 18, 2007 Share Posted January 18, 2007 parerea mea este ca ala e un stabilizator de 3,3v Link to comment
Roland Posted January 18, 2007 Author Share Posted January 18, 2007 banuiam si eu ca se ocupa cu asa ceva dar nu aveam certitudinea...as putea pune un zenner de 3,3V in loc? Link to comment
mircea626 Posted January 18, 2007 Share Posted January 18, 2007 cel mai ok este sa pui un stab de 3,3v in capsula normala.se gasesc in comert Link to comment
Roland Posted January 18, 2007 Author Share Posted January 18, 2007 aha, bun, multumesc pt. pareri Link to comment
Guest byt Posted January 21, 2007 Share Posted January 21, 2007 la problema ta am gasit ic de care vorbeai nu dioda ȚȚȚȚȚ !!!!!!!!!!! MMIC MIXER---INTEGRATED LO AMPLIFIER 3--3.8 GHZ CRED CA MAI DEGRABA ESTE UN AMPLIFICATOR DE SEMNAL MIC ADICA PREAMPLIFICATOR,DACA MASORI OUT (IESIREA )AI UN SEMNAL STANDAR 50mw si 800mv ptr verificare cu un dif de valoare mica poti auzi semnalul sau aparatul de masura ----------------asta sa nu schimbi degeaba ic la SMT AI GRIJA CU LIPITU SI DEZLIPITU ,in rest mult succes .................. :smt006 Link to comment
Roland Posted January 21, 2007 Author Share Posted January 21, 2007 Multumesc mult pt. efort.Problema e ca obiectul e deja ars(e si putin crapat) si alta problema e ca are doar 5 picioruse - 2 pe o parte si 3 pe cealalta.Pe el scrie doar 333E si se afla in zona stab. de 5V, nu vine nici un semnal pe la el.... Link to comment
Guest byt Posted January 21, 2007 Share Posted January 21, 2007 vezi schema nu este obligatoriu sa le folesesti pe toate ???/!!! doar ce este lipit Link to comment
Guest byt Posted January 21, 2007 Share Posted January 21, 2007 ai un mesaj pe privat bogdan Link to comment
Guest mister_rf Posted January 21, 2007 Share Posted January 21, 2007 la problema ta am gasit ic de care vorbeai nu dioda ȚȚȚȚȚ !!!!!!!!!!! MMIC MIXER---INTEGRATED LO AMPLIFIER 3--3.8 GHZ CRED CA MAI DEGRABA ESTE UN AMPLIFICATOR DE SEMNAL MIC ADICA PREAMPLIFICATOR,DACA MASORI OUT (IESIREA )AI UN SEMNAL STANDAR 50mw si 800mv ptr verificare cu un dif de valoare mica poti auzi semnalul sau aparatul de masura ----------------asta sa nu schimbi degeaba ic la SMT AI GRIJA CU LIPITU SI DEZLIPITU ,in rest mult succes .................. :smt006 :smt003 Acum daca ai gasit un cod care se potriveste cu marcajul unui SMD asta nu insemna ca ai acolo un detector de radar sau alta smecherie care merge la cativa GHz... :smt003 Uita-te in schema respectiva si lasa-i sarmanului CD-ROM alimentarea de care are nevoie. :yawinkle: Link to comment
Guest mister_rf Posted January 21, 2007 Share Posted January 21, 2007 Uite un singur exemplu de circuit stabilizator, care foloseste aceeasi capsula (deci nu are 6 pini si foloseste doar 5 :smt001 ) iar marcarea se poate face diferit si Q3XX unde xx este notata saptamana de lucru si 620333YWW iar daca seria este 6203 si tensiunea 3.3 se poate nota doar 333. Oricum tranzistorul extern cred ca este unul PNP si e comandat de circuit. http://www.sipex.com/Files/DataSheets/SP6203_6205.pdf Link to comment
codrut Posted February 1, 2007 Share Posted February 1, 2007 di ce am vazut sigur este o sursa de 3,3 sau 1,8V.mai sigur incearca sa o comanzi la sony Link to comment
