subsemnatul2012 Posted February 15, 2015 Share Posted February 15, 2015 Salutare !Detin urm model de tableta :-)Polaroid mido724pce01.133.Off-ul este ca nu mai porneste,apare scris pe display android si ramane asa.Acest model nu are decat un singur buton,cel de pornit/oprit,si evident acel orificiu ptr restart.Stie cineva cum poate fi inst androidul la acest model,tinand cont ca nu are acele butoane ptr volum.Ms ! Link to comment
Electronicserver Posted February 15, 2015 Share Posted February 15, 2015 Poate te ajuta: http://southerntelecom.com/polaroidsupport/firmware_guide_pmid701c40.html Link to comment
subsemnatul2012 Posted February 15, 2015 Author Share Posted February 15, 2015 Ms !Nu ma ajuta,poate au si altii alte pareri.Astept ! Link to comment
modoran Posted February 15, 2015 Share Posted February 15, 2015 Adica nu merge pasul asta sau care e problema ? With the tablet powered OFF, press and HOLD the MENU button (do not release). While holding the MENU button down, insert the small end of the USB cable into the tablet’s USB port. You will hear a beep, then another beep, at this time, release the MENU button Link to comment
