Jump to content
  • Log In with Google      Sign In
  • Create Account
Răcirea semiconductorilor
  • Please log in to reply
115 replies to this topic
#16 OFFLINE   VEF
VEF
    Membru
  • Membri
  • PipPip
  • 226 posts
Posted 01 February 2017 - 03:37 PM
Am un radiator de 140x40x20 ma intereseaza ce putere ar putea disipa un radiator de asta vreausa il folosesc la un amplificator de 15w cu 2n3055
Posted Image
Edited by VEF, 01 February 2017 - 03:38 PM.
Cu_reclama
Cu_reclama
  • Membri
#17 OFFLINE   ratza
ratza
    Cont dezactivat
  • Membri
  • PipPipPipPipPip
  • 4,948 posts
Posted 01 February 2017 - 03:42 PM
http://www.myheatsin...ance-plate-fin/
#18 OFFLINE   VEF
VEF
    Membru
  • Membri
  • PipPip
  • 226 posts
Posted 01 February 2017 - 04:06 PM
Imi da mai multe valori care sa o aleg din ce inteleg calculul e facut pentru un radiator ventilat articial
Calculation Result: Thermal Resistance & Pressure Drop
Airflow Rate Thermal Resistance Pressure Drop 0.5 m/s (~100 LFM) 2.69 °C/W 0.8 Pa (0.003 inH2O) 1.0 m/s (~200 LFM) 1.94 °C/W 1.9 Pa (0.008 inH2O) 1.5 m/s (~300 LFM) 1.63 °C/W 3.5 Pa (0.014 inH2O) 2.0 m/s (~400 LFM) 1.45 °C/W 5.2 Pa (0.021 inH2O) 2.5 m/s (~500 LFM) 1.32 °C/W 7.3 Pa (0.029 inH2O) 3.0 m/s (~600 LFM) 1.22 °C/W 10.1 Pa (0.040 inH2O) 3.5 m/s (~700 LFM) 1.14 °C/W 12.8 Pa (0.051 inH2O) 4.0 m/s (~800 LFM) 1.08 °C/W 15.7 Pa (0.063 inH2O) 4.5 m/s (~900 LFM) 1.03 °C/W 18.8 Pa (0.075 inH2O) 5.0 m/s (~1,000 LFM) 0.98 °C/W 22.2 Pa (0.089 inH2O
Edited by VEF, 01 February 2017 - 04:08 PM.
#19 ONLINE   Dxxx
Dxxx
    Membru avansat
  • Moderatori
  • 2,252 posts
Posted 01 February 2017 - 04:25 PM
Pe profilul ala nu ai cum sa fixezi (simplu) un 2N3055 - tu cum vrei sa-l fixezi? vrei sa scoti baza si emiterul printre nervurile radiatorului??? ca asa ar fi oarecum "invers".
Cineva cu experienta iti va spune din start ca este cam mic, fara nici un calcul. Plus ca 15W ce spui tu nu prea este relevant... de presupus ca este clasa B...
De curand trimisesem pe cineva catre acest thread excelent al lui UDAR, care la vremea lui a fost total neglijat, desi multa lume ar avea nevoie sa cunoasca ce scrie aici.
#20 OFFLINE   VEF
VEF
    Membru
  • Membri
  • PipPip
  • 226 posts
Posted 01 February 2017 - 04:36 PM
Nu-i o problema ca le scot printre nervuri . amplificatorul e in clasa ab
#21 OFFLINE   ratza
ratza
    Cont dezactivat
  • Membri
  • PipPipPipPipPip
  • 4,948 posts
Posted 01 February 2017 - 04:48 PM
Orice radiator are un curent de aer pe lîngă el, fie el şi rezultatul convecţiei, altfel nu ar funcţiona.
#22 ONLINE   Dxxx
Dxxx
    Membru avansat
  • Moderatori
  • 2,252 posts
Posted 01 February 2017 - 05:57 PM
Un amplificator in clasa B consuma relativ putin cat nu are semnal, deci are sansa sa se raceasca cu un radiator mic.
Unul in clasa A are fix aceeasi disipatie indiferent de semnal, deci iti trebuie un radiator grandios...
Daca estte AB, atunci depinde si cat este curentul de repaus si cum se face tranzitia intre cele doua clase.
Eu iti recomand insa radiator ca lumea pentru 2N3055. cu zona fara aripioare pentru traversarea baza/emiter si supradiemsionat, cum este pe pagina anterioara in postarea lui Flomar.
#23 OFFLINE   ratza
ratza
    Cont dezactivat
  • Membri
  • PipPipPipPipPip
  • 4,948 posts
Posted 01 February 2017 - 06:10 PM
Putem miza pe randament de 65% la un AB, deci 30W disipaţi pe radiator.
#24 ONLINE   Dxxx
Dxxx
    Membru avansat
  • Moderatori
  • 2,252 posts
Posted 01 February 2017 - 06:44 PM
Iar eu pot spune ca cunosc radiatorul ala, si in conditii rezonabile nu vrei sa-l incarci cu mai mult de 5W, asa ca ar trebui sa imparti fiecare tranzistor la 3 radiatoare si mi-e teama ca asta este greu de facut si  inutil atat timp cat exista radiatoare corespunzatoare.
#25 OFFLINE   mars01
mars01
    Haihui
  • Membri
  • PipPipPipPip
  • 1,095 posts
Posted 01 February 2017 - 08:59 PM
In zilele noastre, un ventilator silentios cu bile (sau maglev) numai este o investitie. Iar ventilatorul va lucra ani si ani.
Chiar si un radiator mic de aluminiu daca are montat un asemenea ventilator, eventual subalimentat pentru a fi si mai silentios, poate fi suficient.
Totul depinde de "airflow", cat de repede se evacueaza caldura din capsula in aluminiu si din aluminiu in aer.
LE: citeam undeva pe net ca daca viteza ventilatorului nu este mare, apar nu stiu ce curenti turbionari care diminueaza problema prafului. Nu ca praful ar fi chiar asa mare problema pentru un ventilator cu bile...
Edited by mars01, 01 February 2017 - 09:00 PM.
#26 OFFLINE   marian
marian
    ElForum staff
  • Moderatori
  • 12,721 posts
Posted 01 February 2017 - 10:05 PM
Cunosc si eu radiatorul ala ( e de la mivarom ) si subscriu la ce zice Dxxx ca nu se poate folosi in cazul de fata, eu l-am folosit la o bagheta de leduri care consuma doar cativa W si totusi fara ventilator nu prea l-as lasa...
#27 OFFLINE   VEF
VEF
    Membru
  • Membri
  • PipPip
  • 226 posts
Posted 06 February 2017 - 03:11 PM
Eu vroiam sa fac un amplificator stereo vroiam sa prind 2 radiatoare si sa montez pe fiecare cate 2 finali . Daca prind 2 radiatoare intre el ma gandesc poate  s-ar mai inbunatati situatia
#28 ONLINE   Dxxx
Dxxx
    Membru avansat
  • Moderatori
  • 2,252 posts
Posted 06 February 2017 - 04:02 PM
Din estimarea de mai sus reiese ca trebuie cate 3 bucati de radiator pentru fiecare tranzistor. Deci foarte departe de ce vrei tu.
Iar ochioscopic si din experienta un astfel de radiator ajunge pentru in jur de 5W, asta vorbind de un singur canal cu radiatorul sau. Mai tine cont ca nici aliajul folosit pentru asa ceva nu are conductivitatea termica maxima (adica nu este cel mai bun material posibil).
#29 OFFLINE   sesebe
sesebe
    Membru evoluat
  • Membru activ
  • PipPipPipPipPip
  • 4,039 posts
Posted 06 February 2017 - 05:12 PM
Uite aici un radiator mai aproape de ceea ce ai tu nevoie:
http://www.tme.eu/ro...oare/stonecold/
Rog a nu se considera reclama!
Cu_reclama
Cu_reclama
  • Membri
#30 OFFLINE   VEF
VEF
    Membru
  • Membri
  • PipPip
  • 226 posts
Posted 06 February 2017 - 05:25 PM
Acum eu deja am 3 radiatoare  de la mivarom si n-as vrea sa dau banii pe altul dar vad ca asa la cote si la greutate se potriveste ce vreau eu sa fac cu ce mi-ati recomandat .Am sa incerc asa sa vad ce-o iesi daca nu merge am sa ma orientez la un amplificator mai mic .
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
