Jump to content
  • Log In with Google      Sign In
  • Create Account
Tuburi, Socluri, Nixie, Vfd, Ochi Magic - ultimul post valabil
  • Please log in to reply
23 replies to this topic
#16 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 18 June 2017 - 12:34 PM
Altele de vanzare in BAZAR PICTROM - https://sites.google.com/site/pictrom/
Cu_reclama
Cu_reclama
  • Membri
#17 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 19 June 2017 - 05:45 PM
Tuburi  NOI  /  NOS   sau recuperate SH, dar cu grad mic de uzura.
GU-50 -  18lei/buc SH ca noi - stoc 3
gu50-18rez.JPG?height=150&width=200
6P41S / 6P41C - 20 lei/buc. - stoc 6 SH ca noi
6p41s%20rez.jpg?height=114&width=200
6H2P-EB / 6N2P-EV standard militar ( ECC83 / 12AX7 ) - 8 lei/buc- stoc 152 buc
                                                         Comanda minima 10 buc. + 5 lei posta.
6n2p-ev.JPG?height=150&width=200
6K13P / EF183 - 10 lei/buc - stoc 1 noua
6k13p.JPG?height=150&width=200
5Ц4С / 5T4C / 5T4S  - 15 lei/buc - stoc 0
5Ц8С / 5T8C / 5T8S - 25lei/buc - stoc 2 SH
5t8c%204dec.JPG?height=150&width=200
Soclu din ceramica 5Ц8С / 5T8C / 5T8S - 20 lei/buc - stoc 1 SH
soclu5t8c.JPG?height=150&width=200
6H13C/6N13S - 30 lei/buc - stoc 8 noi
6H13C.JPG?height=150&width=200
6N24P, ECC89 - 10 lei - stoc 5 noi
GMI-6 - 15 lei - stoc 8 noi
GM-70 - 70 lei - stoc 2 SH
gm70%2021mai.JPG?height=150&width=200
6P14P - 7 lei - stoc 9 SH
6P14P.JPG?height=150&width=200
PCL86, PCF82, 2Z-1 - SH, toate 20 lei.
pcl86.JPG?height=150&width=200
6A7 - 15 lei - stoc 1 noua
6J1P-EV, 6F32, 6AK7 – 8 lei -stoc 10 noi
GU-17 - 10 lei - stoc 6 noi
GI-30 - 25 lei - stoc 1 noi
Tuburi ochi magic noi / nos sau recuperate - testate !
Tuburi ochi magic RFT EM84 din acelasi lot, uzate aproximativ 10% inscriptionate  A, B, D, E.
Tubul din mijloc este nou si etalon pentru celelalte.
Pret: 25 lei/buc.
Transportul cu Posta Romana + 10 lei
em84%20uzate.JPG?height=150&width=200
Ochi magic 6E1P (EM80) SH - inscriptionate A,B,C,D,E - 35 lei, F- 45 lei
6e1p%2021mai.jpg?height=102&width=200
Ochi magic 6E1P (EM80) SH - 30 lei/buc.
colaj%20em80.jpg?height=150&width=200
Tuburi NIXIE noi / nos sau recuperate - absolut toate tuburile Nixie sunt testate !
IN-1 - 15 buc - 10 lei/buc, noi
IN-2 - 5 buc - 10 lei/buc, noi
IN-4 - 0 buc - 13 lei/buc, sh
IN8-2 - 0 buc - 12 lei/buc, sh
IN-12A - 43 buc - 10 lei / buc, noi
IN-12B  (cu punct zecimal) - 64 buc - 8 lei / buc, sh
IN-15A simboluri - 17 buc -10 lei/buc, noi
IN-15B simboluri - 2 buc - 10 lei/buc, noi
IN-17 - 5 buc - 15 lei/buc, noi
IN-19A - simboluri - 0 buc - 10 lei - k, ?, ?, m, µ, n, %, °?
IN-19B1 - simboluri - 1 buc - 10 lei - S, F, H, V,T, A, Hz, O
IN-19B2 - simboluri - 1 buc - 10 lei - —, A/B, ~, ?, %, dB, +, <
Z573M - 1 buc - 10 lei - nou
Z1080T - 3 buc - 10 lei SH
colaj%20nixie.jpg?height=150&width=200
IN-14 - 20 lei/buc. - stoc 8 SH ca noi
IN-14%2019iun.JPG?height=150&width=200
3 placi cu tuburi nixie lipite pe pcb - testate
A ramas doar placa A: IN-12B x 3 buc + IN-15A x 2 buc= 30 lei placa 5 tuburi
nixie%20placi.JPG?height=135&width=200
Suporti din plastic utilizati pentru NIXIE IN-14, IN8-2, IN-19, etc.
stoc 49 albe, 6 negre, 1 leu/buc.
suport%20nixie.JPG?height=150&width=200
Drivere tuburi nixie K155ID1 - 8 lei/buc. - 6 buc SH - testate cu Nixie testerul !
Drivere tuburi nixie K155ID1 - 10 lei/buc - stoc 21 noi - testate cu Nixie testerul !
Tuburi VFD - Vacuum Fluorescent Display - netestate !
 IV-1 - 20 buc, 5 lei/buc, noi/nos
 IV-3A - 5 buc 7 lei/buc, noi +1 sh
 IV-3 - 42 buc, 5 lei/buc, sh
 IV-4 - 26 buc, 8 lei/buc, noi
 IV-6 - 15 buc, 5 lei/buc, sh + 13 buc noi 8 lei/buc
 IV-17 - 12 buc, 10 lei/buc, sh
 IV-22 - 10 buc, 10 lei/buc, sh
 IV-26 - 1 buc, 10 lei/buc, sh
Socluri diverse
Socluri GU-50, originale rusesti, din ceramica, cu blindaj 35 lei/buc - stoc 6 SH
socluGU50.JPG?height=150&width=200
Socluri GU-50, din ceramica, cu pini inalti, cu blindaj 35 lei/buc - stoc 3 SH
soclugu50-2.JPG?height=150&width=200
9 pini, magnoval din calit, noi, pe placa/pcb - 8 lei -stoc 7
9 pini, magnoval din ceramica, pe sasiu 10 lei - stoc 0
8 pini, octale  din ceramica, fara colier, pentru sasiu - 10 lei/buc - stoc 3
Socluri din calit pentru tuburi NIXIE IN-12A, IN-12B, IN-15, VFD IV-22
10 bucati pe placa - 50 lei placa - stoc 4 placi
+ 20 socluri recuperate de pe placi la 7 lei/buc.
Condensatori DOORKNOB verificati
Gri-470pF/15kv, 40kvar, noi, diametru 65mm, grosime 25mm, diametru surub 6mm, 35 lei/buc-stoc 9
+ 4 buc SH la 25 lei/buc
Albastri-470pF/4kv, 20kvar, folositi, diametru 45mm, grosime 15mm, diametru surub 5mm, 15 lei/buc-stoc 8.
Gri-150pF/10KV, 9Kvar, folositi, diametru 32mm, grosime 22mm, diametru surub 5mm, 12 lei/buc-stoc 2
Condensator variabil in vid 20-1000 pF, 10 KV, 30 MHz - 500 lei.
-ca nou, extras dintr-un echipament militar.
-parametri precisi si stabili,
-3,5Kg, 150 mm diametru, 270 mm lungime, 12mm diametru ax reglaj
Date de catalog:
Frequency range: up to 30 MHz
Capacity: (20-1000) pF +/-5%
Peak Test Voltage (Upt): 20 kV 30 MHz
Peak Working Voltage (Upw): 15 kV at 30 MHz
Nominal Working Voltage: 10 kV at 30 MHz
I max on 30MHz: 100 A
I nominal on 30MHz: 50 A
P max on 30 MHz: 20 kW
Temperature of work: (-60 to 125) oC (-76 to 257) oF
Dimensions: 60 x 145 D x 258 H mm (2,36"x 5,7"D x 10,16")
Tuning shaft: 12,5 x 20 mm (0,5"D x 0,79"), 40 Turns
Weight: 3.5 kg (7,7 lb)
Operating Position: Any
Material of movinging electrode: special plastic and chemical clean copper.
Transportul este gratuit cu Posta Romana !
Condensator variabil in vid 7,5-350 pF, 10 KV, 30 MHz, 50 A - 340 lei
-diam. max al balonului: 9,5cm
-diam. capete: 6cm
-lungime fara ax: 22,5cm
-lungime ax: 2,5cm
-diam.ax: 12mm
Condensator variabil in vid 5-100 pF, 25 KV, - 280 lei.
GU-47B  pentru liniar SSB 70 Mhz, 4 - 7 KW  - 400 lei.
Poze pentru fiecare in link  - https://sites.google.com/site/pictrom/
Edited by itube, 19 June 2017 - 05:52 PM.
#18 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 20 June 2017 - 01:47 PM
Anunt valabil.
#19 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 21 June 2017 - 12:33 PM
#20 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 22 June 2017 - 03:53 PM
Anunt valabil.
#21 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 23 June 2017 - 01:43 PM
#22 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 24 June 2017 - 02:46 PM
Anunt valabil.
#23 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted 25 June 2017 - 02:45 PM
Cu_reclama
Cu_reclama
  • Membri
#24 OFFLINE   itube
itube
    BAZAR PICTROM
  • Membru activ
  • PipPipPipPipPip
  • 3,700 posts
Posted Yesterday, 11:12 AM
Anunt valabil.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
